Question about Intel S5000VSA Motherboard
Hi, I had intel S5000vsa board thing is i have four SATA HDD and one more SATA dvd .what is the problem is the bios is not showing the DVD.
  • Anonymous May 01, 2009
    THe hard disk was not detecting
  • 58 Answers
It is limited to support only four slots.
Posted on Feb 03, 2009
Intel D102GGc2 shows disk read error when detached sata dvd writer and xp boot when attached the same
Hi. if you're getting the same 'disk read error' when the DVD drive is attached and detached, then the error relates to the hard disk, that you're supposedly trying to install XP onto.
Ultimately you want the board to boot the DVD drive first. A quick change to the 'Boot priority' in the BIOS should sort it.
Apr 27, 2014 | Intel Computers & Internet
Bios not detecting 320gb sata drive
Double check the jumper configuration, You might also want to check the cables and ports incase that's the problem because a properly jumpered SATA drive shouldn't have any compatibility issues. Also check if *********** board supports the SATA ? Let me know if this works..thanks. Mike
Mar 04, 2010 | PC Chips M955G Motherboard
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
What for is sata raid 5 key used for
hello..all new or a lot of new hard disk (HDD) and DVD now is SATA cable connector..Like DVD rom player SATA or IDE cable or HDDrive SATA or IDE cable..
May 11, 2009 | Intel S5000VSA Motherboard
Problem with sata HDD probably?
check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Apr 21, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
Intel Server S5000VSA gives 3 beeps and no BIOS display.
According to the following document (pages 14-19) published by Intel .. That memory module is not listed as tested/working with that board.
Feb 19, 2009 | Intel S5000VSA Motherboard
"HDD REPLACEMENT IS NOT VALID..." error message
Go to http://support.dell.com/support/edocs/systems/latd630/en/AMT/MEBX.htm
You have to disable Intel ME State Control , and you do not get any pop up masages any more.
I hawe that problem with secundary HDD.
Regardes.
Oct 12, 2008 | Pioneer DVR-213LS DVD±R Dual Layer Burner
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Intel S5000VSA Motherboard Logo
158 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
