Question about Matsonic 8328E (MS8328E) Motherboard
Award Boot blockBios v1.0, Bios Check some erreo
  • Peter Steiert
    Peter Steiert May 11, 2010
    So what is it that you are asking, exactly?
  • 106 Answers
Replace your CMOS battery.. heheh ^^
Posted on Feb 06, 2009
How do I install updated BIOS on a Shuttle SD37.
You need to download the Award Flash BIOS to a floppy; then make a Windows bootable floppy (Google for download). boot to the floppy then insert the Award Flash BIOS and your downloaded BIOS image (from Shuttle) and run the BIOS update.
Mar 07, 2011 | Shuttle SD37P2 V2 (SD37-P2-BK-V2) Barebone
Vt82c693a motherboard cant show ide hdd in award gui bios check
There may be a need to check the Jumper settings on the IDE drive, I would make sure the jumper is in the master setting and also to try to keep the cd rom connected also when you boot it up again.
Blessings,
A/V Media Guy
Nov 21, 2009 | Computers & Internet
Cannot boot laptop because of bios password
Easiest way to wipe clean the Bios password is as follows:
  • Perform a power drain by removing laptop battery pack and/or docking station power supply and hold power button down for 10 seconds
  • Locate the CMOS battery (usually under the smallest panel on the bottom of the laptop)
  • Remove CMOS battery for 20 minutes (20 is arbitrary can wait longer if you wish)
  • Replace CMOS battery and panel
  • Replace battery pack and/or replace to docking station
  • Power up
The Bios password should now be removed and you should be able to boot with no issues. Thank you for using Fixya and please remember to return to rate this answer.
Greg
Nov 17, 2009 | Dell XPS M1330 Notebook
When i boot the computer what comes on the screen is (''award bootblock bios v1.0'' copyright(2) 2000, award software, inc bios rom checksum error detecting floppy drive A media insert system disk and...
it means your boot sequence is first booting your floppy drive or your hard disk is not detected.i think you should check the cmos set-up.you can set it by pressing delete while the pc is booting.disable floppy drive seek.also the boot sequence.the os installed is maybe corrupted, is also one of the problem. refer to the manual if you have.
May 16, 2009 | Computers & Internet
I need a bios upgrade. I have a PT800DBP Motherboard Motherboard: CPU Type Intel Pentium 4A, 2833 MHz (7 x 405) Motherboard Name Unknown Motherboard Chipset VIA VT8763 Apollo PT800 System Memory 512 MB...
boot the pc from cold, note the long identifier number - it contains a 2 character identifier for the board manufacturer. For more info go to the Award bios website, it has a better explanation of this. From there you will be able to either download new BIOS from there, or the website of the vendor/manufacturer.
May 02, 2009 | Computers & Internet
Put incorect password in bios and now it's frozen and won't turn
At boot-up note the BIOS provider (Award, AMI, Phoenix, IBM, etc.)
For Award BIOS’ try these backdoor passwords:
AWARD_SW
j262
HLT
SER
SKY_FOX
BIOSTAR
ALFAROME
Lkwpeter
j256
AWARD?SW
LKWPETER
syxz
ALLy
589589
589721
awkward
CONCAT
d8on
CONDO
j64
szyx
For AMI BIOS’ try these backdoor passwords:
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
A.M.I.
CONDO
For PHOENIX BIOS’ try this backdoor password:
phoenix
Apr 12, 2009 | Computers & Internet
How can I change the motherboard boot logo
The EPA logo and the Fullscreen logo all are stored in the bios. That is the update
you download from the manufacturer's website contains both the logos in it. So if you mod the bios update and then apply the patch the next time when you boot your computer you will see the new logo.
***BEWARE A BAD FLASH CAN RENDER YOUR MOTHERBOARD USELESS****
Software Used
Winflash 1.51 ftp://ftp.ecs.com.tw/driver/bios/flash/winflash151.exe
Award Bios Editor 1.0 http://sourceforge.net/projects/awdbedit/
CBROM 2.15 http://www.biosmods.com/download/award/cbrom215.zip
The mods are in two sections.  If you only want one or the other, just skip to that section.
FULLSCREEN LOGO
1. Make Sure the motherboard uses the Award Bios.
2. Either Download the new Bios from the Manufacturer website or get it from the system Bios directly by backing it up.  For backing up and updating bios, I use WinFlash 1.51 (there might be a newer version, I just stick with what works!).
3. Now we have the bios file on disk. Now make a new bitmap image with any of your favorite imaging software. Make sure that the final bitmap image you have created is 640*480 and 256 colors.
4. Now use the CBROM Utility to change the boot logo in the bios file.
This is done by using Command Prompt
c:\bios>CBROM215 bios.bin /logo logo.bmp
5. Now to check whether the bios file was updated correctly. Run the Award bios editor. (make sure the dlls in the plugin directory are moved to the folder with awbedit.exe)
6. Load the bios.bin in the Award bios editor and check in the left hand list for Fullscreen Logo and that it does show your logo.  If okay your bios is now ready to be flashed.
7. Now use Winflash utility, load the bios.bin and click on update .
8. Reboot the computer and the bios logo is changed.
EPA Logo:
Procedure for the EPA logo is just same except the few things.
Image size is : 138*84 16 Colors and 72 pixels/inch
Command for adding to bios file is : c:\bios>CBROM215 bios.bin /epa epalogo.bmp
When you check for the EPA logo in the Award Bios Editor, the colors will not be same as those that you choose but when you flash the bios and reboot, it will show the original colors.
*****PRECAUTIONS*****
Never try to flash bios without a uninterruptible power supply (UPS).
Close all the programs before flashing from Windows.
ALWAYS wait for flash program to notify you for reboot, DO NOT EVER EVER reboot when you think it is ready or taking too long.  Mucking up the flash CAN MAKE YOUR MOTHERBOARD GARBAGE!!!  You have been warned!!
I hope that this helps,
Ken
Jan 07, 2009 | Computers & Internet
Acer aspire 5315 wont boot up
for password, you need to reset your bios. check your bios and enter the password given below:
for AMI BIOS Passwords:
A.M.I.
AAAMMMIII
AMI?SW
AMI_SW
AMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
for AWARD BIOS
01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
BIOSTAR
CONCAT
CONDO
Condo
d8on
djonet
HLT
for Phoenix
BIOS
CMOS
phoenix
PHOENIX
Other Manufacturer BIOS Password
Biostar - Biostar
Compaq - Compaq
Dell - Dell
Enox - xo11nE
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
VOBIS & IBM - merlin
hope this helps!
Nov 12, 2008 | Acer Aspire 5315 Notebook
Her
AWARD_SW
j262
HLT
SER
SKY_FOX
BIOSTAR
ALFAROME
Lkwpeter
j256
AWARD?SW
LKWPETER
syxz
ALLy
589589
589721
awkward
CONCAT
d8on
CONDO
j64
szyx
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
A.M.I.
CONDO
phoenix
Jul 12, 2008 | Computers & Internet
My laptop will not boot up. It goes to a black screen with a blue box in the middle and it asks for a password
now I think I have a solution
bypass a BIOS password. to try on of these standard manufacturer's backdoor passwords:
AWARD BIOS:
AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet, %øåñòü ïpîáåëîâ%, %äåâÿòü ïpîáåëîâ%
AMI BIOS:
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
Other passwords you may try (for AMI/AWARD or other BIOSes)
LKWPETER, lkwpeter, BIOSTAR, biostar, BIOSSTAR, biosstar, ALFAROME, Syxz, Wodj
hope it will help. If some of the codes work, let me know and I will tell you how to remove it.
CS :)
May 15, 2008 | Computers & Internet
Matsonic 8328E (MS8328E) Motherboard Logo
76 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
aravind shet
aravind shet
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
