I am looking for an instruction manual for the danby premiere dpac10071, where would i be able to download or order a manual?
  • 3 Answers
Contact Damby Customer Service @ 1-800-263-2629
Posted on Feb 04, 2009
SOURCE:
Where can i buy accessories for danby premier DPAC12010H
Fixya is unable to suggest sources for Danby parts other than perhaps Danby.
Jul 09, 2018 | Danby Heating & Cooling
Manual for Danby premier ddr30b1gp
The manual for the Danby DDR30B1GP Premiere 30 pint dehumidifier is available on the product page: https://www.danby.com/products/home-comfort/ddr30b1gp/ . Look in the right hand column. The current link to the manual is https://www.danby.com/wp-content/uploads/2017/03/DDR30B1GP__DDR45B1GP__DDR70B1CP_EFSOM_DM_Dec.19.2012_web.pdf .
I hope this helps.
May 09, 2018 | Danby Heating & Cooling
Need manual for premiere r410a
http://www.sylvane.com/media/documents/products/Danby-DDR5009REE-Owners-Manual.pdf
You will need a PDF reader such as Adobe Reader or one of the other free PDF readers. It is a PDF file and will not open as plain text.
Oct 20, 2014 | Danby DDR5009REE 50 Pints Energy Star...
Need a manual for Danby Premiere R410A
Try Googling (Danby)(R410A)(manual) without parens.
Mar 03, 2012 | Danby Heating & Cooling
I have a danby premiere model DPAC10071 & the dehumifier now wont fill external tank. every 2-3 minutes it makes a noise kind of like a fog horn way off in the distance(as if its trying to run again,...
it sounds like your compressor is failing to start ... that usually means a bad starting capacitor ... if thats the case it will hum loudly for a few seconds periodically .. thats the compressor trying to start but it cant if the capacitor is bad .. it will stop humming when it gets too hot .. a thermal breaker will turn off the power until it cools back down .. dont let this continue since it will eventually damage the unit ... replace the capacitor .. the capacitor is usually mounted on or near the compressor .. it often has two sections .. one for the fan motor and one for the compressor ... since they are both in one case you have to change them both ,...
Aug 15, 2010 | Danby Heating & Cooling
I'am looking for an owner's manual Danby DDR 451
You can get the manual on the link below. Click on where it says it is free PDF then click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/DANBY/DDR451-_E
Good Luck
May 26, 2010 | Danby DDR451 Dehumidifier
Replace window mount for dpac 120068
GO TO DANBY.COM AND GET FULL SPECS FROM THE MANUFACTURERS WEB SITE. IF YOU WANT TO KNOW IF YOUR MAKING A GOOD TRADE OFF, LOOK FOR BTU'S , WATTS, AMPS, STAR RATING PER YEAR ETC...IF YOU WANT TO REPLACE JUST THE WINDOW MOUNT, THEN GO TO DANBY.COM, OR LOOK IN YOUR OWNER'S MANUAL TO ORDER A REPLACEMENT MOUNT. IF YOU JUST NEED TO KNOW HOW TO RELACE THE MOUNT , THEN CONTACT SUPPORT AT DANBY.COM AND ORDER WHAT YOU NEED, A MANUAL , INSTALLATION INSTRUCTIONS, GUIDES, AND IF YOU ALREADY HAVE THESE MANUALS , THEN JUST READ THE MANUAL ON HOW TO INSTALL A MOUNT OR REINSTALL A NEW ONE.
Apr 13, 2010 | Danby Portable Air Conditioner
Danby PORTABLE Air Conditioner model DPAC10071 is leaking water from bottom base. The unit is 2 weeks old.
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Jun 27, 2008 | Danby Heating & Cooling
Heating & Cooling Logo
789 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
