Question about Mercury P4VM800M7 Motherboard
Mercury sir iam gangadhar iam using mercury motherbopard modelPVM7 ver 3.1 iam unable to install to winxp-sp2 ,it gives error in blue screen .and one slot of dimm is not working ,system always geting shoutdown & restart.
  • 64 Answers
Replace bad DIMM, then install XP.
Posted on Feb 07, 2009
Get blue screen and igxprd32 error on hp dc7700s
1. Fresh install winxp sp3
2. Copy igxprd32.dll to windows/system32 folder (ver.6.14.10.5134)
3. Install Advanced PC Tweaker ,use once, scann and fix system and registry
4. Install all updates from microsoft, restart, then
5. Chipset sp38488 ,HECI sp34743 ,Audio sp39852 , and Network sp51788 (with error,but ok from divace menager/update driver)
6. Finally, install Gpaphic adaper sp42426 ,from HP support site
all drivers from above :
http://www.4shared.com/folder/Le7Nurhj/HP_DC7700.html
Jan 18, 2011 | Computers & Internet
Upgrade of WinXP home to SP2 failed on 3 attempts. System just reboots and reboots. Got message from Microsoft that my bios does not match the CPU. MB is P4VXASD. BIOS is AMI 07.00T ver 2.3 4/2/2001
Hi, you give us the M/B and Bios but don't say what the CPU is? What is the complete message you got from WinXP? SP2 often gives that message when you have changed your CPU, or Flashed your BIOS sometimes other hardware changes. SP2 recognises that something has changed since your first install of XP, and that message is usually not an error exactly, but part of a bigger message. That is usually just the part where SP2 says "by the way, as I was fiddling about I noticed that the BIOS and CPU are different to what I expected" Failures after applying a service pack are rarely anything to do ith BIOS or CPU especially if the system was working OK before applying the patch. Have you Flashed your BIOS very recently? like just before apply SP2? Most likely is that a file is corrupt, often NTKRNL, Please give more detail on how you applied the Spack, and all error messages thanks SB
Sep 02, 2010 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
Unable to install for winxp
that means its not compatible.Check your modem which windows are required to use it.
Feb 18, 2010 | D-Link DSL 200 (DSL-200) Modem
Installing winxp
You must put your CD installer to the CD reader of your PC and Click Install , Confirm and Confirm.
Feb 15, 2010 | Computers & Internet
I cannot install OS winxp onto sata drive pc is Acer aspire x3200
There could be two reasons for the blue screen either a bad harddrive or loose memory cards in the slots. Try reseating the memory cards on the motherboard.
Also please post back the Stop code you are getting on the blue screen
Thanks for using Fixya
proton
Jul 27, 2009 | IBM SYSTEM X3200 M2 E4600 2.4G 2GB 2MB...
W200 cause a blue screen
First of all: If you install SP2 you don't have to install SP1 over it. It already did. Secondly, don't install SP3, it destroys Windows XP.
Try reinsalling the PC with SP2, install the drivers and do nothing else, see if that helps.
If not, by all means post back here,
Yannick.
Jun 16, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Blue screen of death on DELL Inspiron 9300 WinXP pro SP2
Clean install windows xp :) or do a repair
Jun 04, 2008 | GE EasyCam Webcam
Mercury P4VM800M7 Motherboard Logo
49 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
