Question about Dell OptiPlex GX280 PC Desktop
Problem withe dell gx280 fan and display
I have dell optiplex GX280 when i press the power button i dont get any display and cpu fan reach to its max speed how can i fix this prob?
I had exactly this problem on an Optiplex GX 280.
I replaced 1 stick of ram, and everything was happy.
Posted on Jun 03, 2010
Unfortunately this seems so be a motherboard problem, Dell's solution is to replace the motherboard I'm not sure there's much you can do at home or work to fix this - if it's still under warranty get dell to replace the motherboard if not im afraid its the bin for it sorry
Posted on Feb 05, 2009
3 Suggested Answers
damnor01
  • 1179 Answers
SOURCE: i have dell optiplex GX280
Go through my published guide with regards to this matter, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Happy testing!
Thanking you!
damnor01
Posted on Nov 23, 2010
nerdvana
  • 120 Answers
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google this and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Posted on Feb 20, 2011
Feb 11, 2011 | Dell OptiPlex GX280 PC Desktop
Power or motherbaord failure
open it ...remove the bios battery and after that put it back ..this will reset it ...and will boot ...just set the time and date and press f10 to exit and save ...
if it still fail to boot after that it has another issue ..probably a cpu fan or a ram memory
Jan 18, 2010 | Dell OptiPlex GX280 PC Desktop
Dell gx280 no post cpu fan spins on max
What have you tried so far? Whenever I deal with a no post issue.
1. Disconnect all the connection at the back of the computer tower and power cycle it by pressing the power button of the tower for 15 seconds and plug the power cord back in and the monitor only.
2. If no post didn't occur, plug the devices one-by-one until you see the faulty device
3. if none of the external device causes the problem
4. We'll have to open the computer tower and reseat the video card, hard drive, memory, cpu power supply.
doing things one-at-a-time is the best thing to isolate the issue and point the root cause of the problem. Let's hope that it's not a problem with the power supply or motherboard.
Jan 06, 2010 | Dell OptiPlex GX280 PC Desktop
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
CPU Fan Failure on Startup
if you have tried changing the fan then the problem is with the motherboard & motherboard needs to be replaced.
Apr 25, 2009 | Dell OptiPlex GX280 PC Desktop
Dell GX280 High Speed Fan and No Display.
i had same problem today and i tested my machine and solved the problem at last.
the problem is the thermal value that your mainboard sets for your cpu.
please replace the mb.
ps: before this process,i tried almost everything . cpu fan , memory , cpu , cables ,case ... everything. but the problem is on your mb.
Feb 04, 2009 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
1,108 people viewed this question
Alun Cox
