My Computer is not work & cotrolpannel
Khatra.exe various has come then contropannel is gone & when I right click my computer or click proerties come ddisplay ti pls check computer administration.
    Scholar:
  • 116 Answers
Looks like a virus or trojan, disable everything in MSConfig (see this article) the hopefull you can go online and do a online scan like http://housecall.trendmicro.com, you may also want to download the free malware tool from malwarebytes.org
Good Luck, hope this helps
Posted on Feb 04, 2009
The iomega hard drive says its empty but the drive is almost full.
click start control panel administration tools computer management disk management right click on your drive select proerties from there you will see all used and free space on your hard drive also if you select tools another check now tick in both boxes auomatically fix file system errors and scan for and attempt recovery of bad sectors this will schedule on restart you should not have any input while the chkdsk utility is in progress any input may damage your computer
hope this helps
Apr 15, 2011 | Iomega Computers & Internet
I have product id how to get productkey for windows 7
click start right click on my computer select proerties you will see all the computer information
or if you have not purchased your copy $7.49
http://www.quicksales.com.au/buy/auction.aspx?itemid=11652304
Feb 22, 2011 | Computers & Internet
Gloriwhen i turn my laptop on all it shows is a small computer and a padlock i cant go anywhere on it i have no start button or nothing
It seems as if the explorer.exe file has gone corrupt or is not loading on starting the computer.
Press CTRL+ALT+DEL
Click on task manager
Under the process tab.. try searching for explorer.exe
If its there, then right click on it and click end program
If its not there, then click on FILE tab on upper left hand side corner
Click on "New Task"
Type explorer.exe
That should bring your desktop back again.
If it does then run a virus scan and other security scans to make sure that it was not because of some infection.
If you need any further help.. then logon to HNetworking.com or call us at 859 309 7078 and we will try diagnosing your problem completely.
Admin
HNetworking.com
Jan 28, 2011 | Dell Dimension 2400 PC Desktop
C:\windows\system32\KHATRA.exe error problem. from XP sp/2
Hi. WARNING !!!! KHATRA.EXE is a VIRUS!!
I HIGHLY reccomend that you go to microsoft's website, and download microsoft security essentials.
This is a highly efficient anti-virus/anti-spyware, and anti-malware program, that not only will keep your computer clean, it will provide real time protection against all known threats!
Khatra.exe is actually part of a group of files that will be located in the located in the windows/system32 directory
Khatra.exe, gHost.exe, and xplorer.exe
Here is the solution on how to remove them
Download this program, it is called Stopzilla, and it will clean and disinfect your entire system.
Here is a link for the program: http://www.virusremovalguru.com/software/stop.php
It is really good for this type of viruses.
It also will not conflict with microsoft security essentials, so you will have anit-spyware and anit-virus that can run independent scans at the same time!
I hope this helps.
If you cannot access the internet, due to the infection, use someone elses computer, download the files for both programs, and burn them onto a cd, this way you will also have an emergency rescue type disk, should this happen again.
Jan 24, 2011 | Computers & Internet
I just bought this scanner and have windows vista hooked it up and nothing. i do not have a disk
How to get the Artec 1236USB/Ultima 2000 scanner working in Windows Vista. Note that this how-to skips the various UAC prompts that occur throughout the process.
1. Right click on the Setup executable (whatever the name is, also assumes the full 22MB file) and then select the Compatibility tab. Set compatibility settings to Windows XP (Service Pack 2), and set the program's Privilege Level to run as administrator.
2. Install the scanner drivers and reboot the computer.
3. Go into Control Panel, select System, then select the Device Manager. Select the scanner, which should appear as an unknown item on the list. Right click on the unknown and select Properties, then select the Driver tab. Select the Update Driver button and let it search for the Artec drivers. A warning will appear regarding the lack of a digital signature. Tell Windows to install the driver anyway.
4. Reboot computer.
5. Search for Scan32.exe or open an Explorer window and drill down to c:\windows\twain_32\artecusb\.
6. Right click on Scan32.exe and select the Compatibility tab. Set compatibility settings on scan32.exe to Windows XP SP2 and make sure the executable can run as an administrator.
7. If desired, repeat this process with ScnPanel.exe in c:\program files\artecusb\scanpanel\. My personal opinion is that ScnPanel.exe is redundant, the aforementioned scan32.exe file being far more flexible. It only serves to use up resources, so I wouldn't bother with making the file compatible and would just remove it from the Startup group.
8. Start scanning.
Hope this is helpful and fix the issue.
Thank you for contacting FixYa
*Please rate this solution with a thumbs up
Nov 16, 2010 | Artronix Technology Artec 1236 Flatbed...
I have a Dell Inspiron 6000 with windows XP, McAfee Security Suite, and a Verizon USB for internet. When I turn it on I get an error message: dlbcserv.exe has encountered a problem and needs to close. ...
This error message is a result of your Dell printer software functioning improperly.
This is a 'quick fix' to get rid of the error message:
  1. click 'Start'->'All Programs'->Startup
  2. Right click on dlbcserv.exe and click 'delete'
PS: dlbcserv.exe is a Windows process installed alongside Dell Photo Printers and provides additional configuration options for these devices. Although it is not an essential process for the operating system, you should not remove & uninstall it unless it is causing serious problems and errors.Dlbcserv.exe is a Windows file created by Dell. The file is usually found in Program Files\Dell Photo Printer 720\dlbcserv.exe folder. If you find it anywhere else, Please note that dlbcserv.exe could be a virus, trojan, worm, or spyware. Scan your computer with an antivirus software to make sure it is not infected.
Aug 10, 2010 | Dell Inspiron 6000 Notebook
My system is showing an error during login as C Windows system32 KHATRA exe could not run what can i do
i think your system files are corrupt. During the boot process hit f8 u sould get a boot menu try clicking on last known good configuration if not go to youd bios menu and choose boot from Cd/DVD under boot device menu then insert your operating system CD/DVD and use the option Repair to repair your OS.
Jul 05, 2009 | Computers & Internet
Though Khatra.exe has been deleted by my antivirus, I am not able to access the registry in the system and also not able to change the desktop properties, it gives the message "restrictions in the system,...
Ok if the virus and its drops is actually been removed. Then try to use REMOVE RESTRICTION TOOLS. it is a stool tool. Goggle it, download and run. Then reboot your computer. It runs on XP. Don't use it in Vista coz I still not tried that.
Jun 03, 2009 | Intel Computers & Internet
Sound is not coming from the pc.
Hi prakhar,
Click start>my computer,right click>proerties>hardware tab>device manager>navigate to the codec that is your sound card>uninstall>reboot and check sound.
anaanymous
Oct 16, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
