Question about Acer Aspire 9300 Notebook
Usbaudio.sys in Vista fails to set up usb sound adapter
Acer Aspire 9300, AMD Turion 64, 1.6GHz, 4 GB DDR2.
This problem stops me from using Speech Recognition (no working mic):
Vista tries to set up an Andrea or Parrott usb sound adapter (half duplex), identifies it as an Audio Device, but in the end fails to set it up (yellow triangle+?).
The same machine, running WinXP sets up these devices without a hitch. I've tried replacing usbaudio.sys in Vista with the same file from XP, but no joy. I've tried updating my AC'97 drivers, but that didn't work. Can someone help?
Does my acer 5535 have a webcam
According to the specs. it does not have a WEBcam.
This is the specs.
Aspire 5535 Series Specifications
Part Number: Aspire5535 Aspire 5535
Feature Description Part Number Varies by specifications Processor / Speed AMD Turion™ X2 Ultra dual-core mobile technology ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1 MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology. Core Logic Chipset AMD M780G Chipset. System Bus Speed 667 MHz. RAM / Max RAM Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules. Video Subsystem ATI Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of dedicated system memory, up to 1792 MB of shared system memory), supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR) technology, Shader Model 4.0, Microsoft® DirectX® 10.0. LCD Properties Display 15.6" HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time. Hard Disk Drive 120/160/250/320 GB or larger hard disk drive. Optical Drive 8X DVD-Super Multi double-layer. Battery, Primary 48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use. Sound Subsystem Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone. PCCard Support 1 ExpressCard™/54 slot. Pointing Device Touchpad Peripheral Subsystem ExpressCard™/54 slot.
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model) Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model) Dimensions / Weight 15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack. AC Power 100-240V AC AutoSensing Adapt
Dec 23, 2010 | Acer Computers & Internet
My Acer Aspire 5520G will not play a Blu Ray disk. It keeps telling me that I need a critical update to the Acer Archade DVD playing software. When I click on the update button it comes back with a message...
from these derived specs You do not have a blue ray drive installed in this you have a DVD drive so of course a blue ray would not play in this unit. Specs are below from acer
CPU: AMD Turion 64 X2 TL-58, 1900 MHz [(9.5 x 200), L1 cache 64 KB/core, L2 cache 512 KB/core - dual-core, 64 bit support]
Motherboard Chipset: nVidia nForce 7000M-610M (southbridge), AMD Hammer DDR 2 IMC (northbridge)
BIOS Type: Phoenix
RAM: 2048 MB [667 MHz DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)]
Video adapter: nVidia GeForce 8600M GS, 512 MB GDDR2 [128 bit, core clock 600 MHz, shader clock 1200 MHz, memory clock 700 MHz - support for DirectX 10]
Monitor: Acer CrystalBrite 15.4" LCD (LG Philips), WXGA [8 ms/220-nit, currently running at 1280x800@60Hz] - HDTV capable
Audio: Realtek ALC268 @ nVidia MCP67/68 - High Definition Audio controller; Dolby Sound; audio jacks (on the front side): headphones, microphone, S/PDIF
Networking: nVidia MCP67/68; (wireless) Atheros AR5007EG - 802.11 b/g
Storage: Hitachi - 160 GB [8 MB cache, SATA, 5400 RPM]
Optical drive: Mats hita - 2 MB cache, DVD +/- R/RW/RAM/ROM, dual layer support, CD R/RW/ROM
Card reader: Ricoh - 5-in-1: SD, MMC, MS, MS PRO, xD
Webcam: Acer Crystal Eye (Bison) - 0.3 Mpixels
Connectivity:
4 x USB 2.0,
Broadcom Bluetooth adapter,
CXT Fax/Modem - 56K, V.92,
DVI,
ExpressCard,
IEEE 1394 (FireWire),
VGA,
RJ-11 (modem),
RJ-45 (Ethernet),
CIR (Consumer Infrared),
S-video/TV-out (NTSC/PAL)
Battery: Lithium Ion, 6 cells; (initially) discharge time ~3 hours
let me know
please do leave feedback and ratings for your free answer today.
May 08, 2010 | Acer Aspire 5520-5908 Notebook
Hi What is te type of disc installed on ACER Aspire 5022 WLMI 100 GB? What is the rotation speed of this disc? Thks
rocessor - AMD Athlon X2 QL-64 / 2.1 GHz ( Dual-Core )
  • RAM - 4 GB (installed) / 4 GB (max) - DDR2 SDRAM
  • Hard Drive - 500 GB - Serial ATA-150 - 5400 rpm
  • Operating System - Microsoft Windows Vista Home Premium
  • Screen - 17.3" TFT 1600 x 900 ( WXGA+ ) - 24-bit (16.7 million colours) - CineCrystal
  • Optical Drive - DVD±RW (±R DL) / DVD-RAM - integrated ... [ more info ]
  • Sep 04, 2009 | Acer Computers & Internet
    AMD Turion 64x2 Processor Upgrade Problem
    Yes it's the BIOS, which holds a list of supported CPUs (with the right min/max settings for Vcore, FSB, multiplier (or HyperTransport as it's called for AMD chips), etc.). When you put in a newer unrecognized CPU, it either runs at a failsafe (very slow) setting or won't boot at all.
    The only solution is to flash a newer BIOS version which supports the CPU. I searched the Acer website and found the newest BIOS version 3315 (dated 2008-12, which is pretty new imho), which you can download (including the required flash software) here: http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_3315.zip?acerid=633643256207419447&Step1=Notebook&Step2=Aspire&Step3=Aspire 5050&OS=V10&LC=nl&SC=EMEA_18
    Perhaps you already have this BIOS version and I'm not sure wether your new CPU is supported by this BIOS, but you might give it a try.
    Please note that flashing your BIOS might fail & brick the laptop and is at your own risk, but when following the instructions carefully, it's only a very small chance things go wrong. I've done it a dozen times without any problem ...
    Aug 11, 2009 | Acer Computers & Internet
    Ihad a ACER Aspire 5052AWXMi, AMD Turion MK38,
    yes you can upto 2GB and 160GB HDD
    bkas your laptop having DDR ram, 80GB is ATA HDD,
    Jun 22, 2009 | Computers & Internet
    Laptop
    here are some details below find the right one and take it
    Model No: TM 2403NWXCi
    Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
    RAM: 256 MB DDR2 400 RAM
    HDD: 40 GB
    Optical Drive: DVD-Rom/CD-RW Combo Drive
    Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
    Graphics: Intel GMA900
    Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
    Weight: 2.38 KG
    Battery: 6-Cell Lithium Ion Battery
    O.S.: Linux
    Warranty: 1-Year Global Warranty
    Price: Rs. 27,999*
    Model No: TM 2424NWXCi
    Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
    HDD: 40 GB
    Weight: 2.35 KG
    O.S. : Linux
    Price: Rs. 28,499*
    Model No: Aspire 5002NWLMi
    Platform: AMD Turion 64 ML-30 (1.6GHz)
    RAM: 256 MB DDR333 RAM
    HDD: 60 GB
    Optical Drive: DVD-Dual Double Layer drive
    Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
    Graphics: N.A.
    Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
    Weight: 2.9 KG
    Battery: 8-Cell Lithium Ion Battery
    O.S. : Linux
    Price: Rs. 37,999*
    Model No: Aspire 5004NWLMi
    Platform: AMD Turion 64 ML-34 (1.8GHz)
    HDD: 60 GB
    Graphics: N.A.
    Weight: 2.9 KG
    O.S. : Linux
    Price: Rs. 38,499*
    Apr 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
    To u my friend
    nothing much buddy ...
    HDD: 40 GB
    Weight: 2.38 KG
    O.S.: Linux
    Price: Rs. 27,999*
    HDD: 40 GB
    Weight: 2.35 KG
    O.S. : Linux
    Price: Rs. 28,499*
    HDD: 60 GB
    Graphics: N.A.
    Weight: 2.9 KG
    O.S. : Linux
    Price: Rs. 37,999*
    HDD: 60 GB
    Graphics: N.A.
    Weight: 2.9 KG
    O.S. : Linux
    Price: Rs. 38,499*
    Model No: Aspire 5502ZNWXCi
    Platform: Intel Centrino Mobile Technology based Processor Pentium M 735A (1.7 GHz / 2MB L2 Cache / 400MHz FSB) / Intel 915GM Express chipset.
    HDD: 60 GB
    Optical Drive: DVD+CDRW Combo Drive
    Display: 14.1" WXGA CrystalBrite TFT with 1280 x 800 resolution.
    Graphics: N.A.
    Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 2 USB Ports.
    Weight: 2.38 KG
    Battery: 6-cell Battery
    O.S. : Linux
    Price: Rs. 40,499*
    Model No: AS 1641NWLMi
    Platform: Intel Centrino Mobile Technology based Processor PM 725A (1.6 GHz / 2MB L2 Cache) / Intel 915GM Express chipset
    RAM: 256 MB DDR2 533 RAM
    HDD: 60 GB
    Optical Drive: 8X DVD-Dual Double Layer Drive
    Display: 15.4" WXGA CrystalBrite TFT with 1280 x 800 resolution
    Graphics: N.A.
    Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 3 USB Ports
    Weight: 2.38 KG
    Battery: 4-cell Battery
    O.S. : Linux
    Warranty 1-Year Global Warranty
    Price: Rs. 42,499*
    Apr 14, 2008 | Computers & Internet
    Acer aspire 5100 + AMD TURION 64 + DDR2 1GB + WINDOWS VISTA - IS VERY SLOW, AND HANGS
    hmmmm...now..that's weird..did you do any disk maintenance? shut down all applications, all of em, and run disk cleanup and defrag..usually good for about 25% improvement in speed, at least..
    got backup for that acer?
    Feb 21, 2008 | Acer Aspire 5100 3010 Notebook
    Acer Aspire 9300 Notebook Logo
    672 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
