Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
Cant get photo's to come up on computer/frozen usb
The light flashes,the computer reconizes it, but cant get the photo's to come up.......??? any tips please.
  • 58 Answers
Hi there...it's indicate there is a vrus in your flash drive.. the virus is hiding and manipulate your file so you can't the file when connected with your computer.
if you have recovery program that already install at your computer you can backup the file that you need after you format the flash drive. but if you don't have program don't format the flash drive.
maybe you can visit a nearst software store and asking recovery program (ex: office recovery) buy it, install to your computer and you can formatted the flash drive back up your photo using media heal for removeable drive...good luck..
Posted on Feb 02, 2009
Cant transfer pictures to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Apr 04, 2014 | Canon PowerShot SD750 / IXUS 75 Digital...
Hello, my 8gb Sandisk light is keep flashing and is not bieng reconized by my laptop.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
good luck.
Feb 17, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I cant copy pictures from my computer to my flash drive im using transcend 2 GB
flash drive may have a locked (read only) so change the lock status to unlocked
try to copy photos again
Apr 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My computer does not reconize my flash drive
check of you usb is enabled in bios setup, check in device manager if your flash drive detected or else your flash drive already defective.
Apr 09, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
B4 i could connect my f480 touch to the computer but now i cant.
if it is having that error try using the other USB port on your PC...
Jun 30, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
My sandisk imagemate my computer wont reconize the device
you need the correct driver
sandisk.com
driverguide.com
Jun 25, 2009 | SanDisk 2GB microSD Memory Card
I can't get my Compac Evo N610 to reconize my docking station usb ports what do i do?
I have a solutions that might work, please for the love of god, next time give it as much detail as possible. Navigate to Start>run type:MSCONFIG. Enable everything unless you are absolutely sure you don't need it.
Right click on My Computer, click on properties. Go to the hardware tab at the top, click on device manager to see if there is a conflict.
Try a different port.
Try the hub on a different computer.
If your hub has a power input, now would be the best time to plug it in.
Plug directly into computer.
Make sure the device is plugged in securely, same goes for the devices plugged into it.
If that port is for power only and you plugged it in thinking it would work for data, please don't ask.
Any error messages?
If your computer can boot off a flash drive, Go to bios, test the port and the hub.
May 08, 2009 | Computers & Internet
My Zen V Plus is really screwed up
Sounds like a similar problem I had today.
My Creative Zen V Plus wasn't recognised by my PC, then it wouldn't even switch on.
Following the solution of another similar problem on here I fixed it. Connect your Zen via USB to your computer and press the reset button. Should spring to life and start re-building your library. I am as I type adding new tracks to mine :))
Apr 04, 2009 | Creative Labs ZEN V Plus MP3 Player
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
50 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
