Question about HP Compaq Presario F750US
Com surrogate whenever i boot my system it pops me the msg saying com surrogate has stopped working please check online>>>
  • 29 Answers
First check if you have nero or Divx installed. Then uninstall it.
Right click on Computer, and choose Properties
com surrogate - clip_image0021.jpg Click on Advanced System Settings, and then under Advanced, click Settings
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select�
clip_image00221.jpg Click on the Add button, and then browse to C:\Windows\System32\dllhost.exe as shown
clip_image00231.jpg Click Open, and then OK.
Here's what you should see…
clip_image00241.jpg Now you can browse video folders without problems!
Posted on Feb 06, 2009
If I diable com surrogate will it harm my computer
Com surrogate is a service that allows switching on the com ports. Without it, communication to your devices will stop. If you're encountering this error there is a driver problem with your com port controller and you need to install the correct drivers.
Sep 01, 2014 | Microsoft Windows Vista Home Premium...
Com surrogate has stopped working.
find the link for the software u need on this website http://vistatipsforall.blogspot.com/2007/05/com-surrogate-has-stopped-working-error.html
May 31, 2009 | HP Computers & Internet
Com surrogate
These should help:
http://www.howtogeek.com/howto/windows-vista/fix-for-com-surrogate-has-stopped-working-error-in-vista/
http://www.superbdevelopment.com/forums/general-tech-talk/3600-windows-vista-com-surrogate-has-stopped-working-fix-solution.html
http://www.mydigitallife.info/2008/06/13/how-to-fix-com-surrogate-problem-when-opening-video-format-files/comment-page-1/
Error message: "COM Surrogate has stopped working."
COM objects are often defined in Dynamic Link Libraries (DLL files). The Program file for COM Surrogate is actually dllhost.exe that can load a DLL and make its objects available to other programs.
The COM Surrogate error message is often related to codecs and other COM objects that aren't fully compatible with Vista. These are installed by other programs. The most common culprits are DivX and Nero. The first thing you should do is upgrade to the latest versions of these to see if that fixes the problem. Another possible fix is to disable thumbnail previews in Explorer. To do that:
In Windows Explorer, click Organize, then select Folder and Search Options
Click the View tab
Check the box that says "Always show icons, never thumbnails"
Click OK
To help troubleshoot which codec(s) might be causing the problem, you can use a free tool called InstalledCodec. You can use it to disable individual codecs one at a time.
You can download it at http://www.nirsoft.net/utils/installed_codec.html
Hope that helps
Mike
May 13, 2009 | Dell Inspiron 1521 Laptop
COM Surrogate shut of, no desktop
hit F8 right after the main boot screen to bring up the startup menu, tell it to use LAST KNOWN GOOD CONFIG
Mar 20, 2009 | Microsoft Windows XP Professional
COM surrogate stopped working. What can i do ?
Easy solution, click start, control panel, system. choose advanced system settings. Under the tab of advanced you will see performance, click on settings for that. Choose the tab that says data execution prevention. Click the button that says turn on DEP for all programs except for the ones I list. Then click on add. The file is in windows, system32 folder c:\windows\system32 and the file name is dllhost.exe You will add it to the list as described and press apply this will prevent the error.
Dec 06, 2008 | Microsoft Windows Vista Ultimate Edition
http://fileforum.betanews.com/detail/Vista-Codec-Package/1159994557/1
Just download this small program and everything should be just fine . I was having the same problem , ive been told that its because of nero or divx codecs , didnt unistalled anything just installed this program and my problem was solve !
Nov 28, 2008 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Com surrogate and run ddl 32 problem
download codec pack and install it, ex - k-lite codec pack its free on net
Nov 11, 2008 | Microsoft Windows Vista Ultimate Edition
Software problem
Hey there
You get an error message that COM Surrogate has stopped working whenever you browse folders containing video or media files, This problem is caused because of codecs and other COM components installed by various softwares that aren't fully Vista-compatible, like some versions of DivX or Nero.
There are a number of possible solutions to this problem, and the right solution depends greatly on what software is actually causing the problem.
If you are using DivX, you should be upgraded to the very latest version (6.5+)
If you are using Nero, you can try upgrading to the latest version (7.7.5.1+)
If you’ve upgraded Nero and Divx and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax to NeVideo.ax.bak. You may also need to rename NeVideoHD.ax to NeVideoHD.bak
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate) can fix this problem . This solution is detailed below.
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select”
Gimme your Acknowledge by rating me
thanx
Romy
Jul 31, 2008 | Microsoft Windows Vista Ultimate Edition
HP Compaq Presario F750US Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
