Question about Dell Inspiron XPS M140 Notebook
2007 DELL XPS M140 LAPTOP WILL LOCK DUE TO 256M MEMORY STICK
I don't know what happened a week ago. Only way I can bootup the laptop by removing the memory stick. Dell has a built in 256M on the motherboard which allows complete computer ops, but extreme slow. I have replaced the original stick with new ones of 512M 1.0G memory stick, but no help. I have done Dell Diagnostic. All components testing OK. I have checked the software enviornment, but do not detect any conflict. I am getting not much help on Dell site. I would appreciate if anyone can give me some help here.
  • anwa767 Feb 02, 2009
    boot sequence was already setup by Dell. USB was #3. I even took out USB from the boot sequence, but no help. During start, 3 LED lites light up. Middle one looks like a lock (A) blinks 8 times, then pwr shuts down. 512M & 1.0G memory sticks I bought, the dealers swore that it is compatible with my laptop. Sometimes I keep pressing start button, it will start but stops with a statement something like your *memory has changed, reducing amount of memory* & then nothing happens. Any help?
  • Dell Master
  • 32,281 Answers
Normally you boot up the laptop without a memory stick in the USB port.
Check your BIOS settings for the boot up device order.
You should have the hard drive as the first boot device, you can have the CD as the first boot device and the hard drive as the second boot device.
You should not have the USB port as the first boot device.
Posted on Feb 02, 2009
  • Chris Hingee
    Chris Hingee Feb 02, 2009
    You had me confused "the mempry stick" you referred to is not the USB memory stick but the memory modules (ie. RAM), now I understand your problem.
    You have purchased two memory modules, one 512Mb and one 1Gb. am I correct?
    Your laptop has two memory slots and the specs for your model state that it will support 512Mb to 2Gb of RAM. The RAM must be DDR2 with speed of 400Mhz or higher. (If you use slower memory or a mix of slow and fast memory, the computer will run with the slow memory speed).
    When you insert more memory into a computer the BIOS detects there is a change in memory capacity and normally you need to configure the BIOS to reflect the change in total memory size. Then reboot your computer and it will boot up normally.
    If your computer does not boot up normally then you have a memory problem (ie. RAM), and this could be :-
    1. The wrong type of memory module (see the specs.).
    2. The new memory module is incompatible with the existing memory module (your existing 256Mb module won't work with the new modules). To test if the new memory modules will work in you computer, remove the existing 256Mb module and insert the 512Mb or 1Gb memory module in the computer and see if it works.
    If both memory modules work separately in the computer, then insert both the new memory modules in the computer to see if it works. If it does then you are OK with 1.5Gb of RAM in your computer. If it works with the 1Gb memory module that is OK too, it is better that the original 256Mb.
    3. It could be that the RAM needs to be inserted in matching pairs (ie 2X256Mb or 2X512Mb or 2X1Gb) but not mixed memory capacity modules. This usually isn't a problem.
    Try these solutions, it should solve your memory problem.
    Remember next time you have a problem, try to give as much precise info as possible together with error messages etc.
Need to reset the bios password on my dell xps m140 laptop.
You would have to reset the whole bios to default which maybe something you cannot do. The only other method would would be to take the laptop apart and remove the battery that keeps the motherboard BIOS memory powered. It should look like a large watch battery. Remove for 5 to 10 seconds, and replace. Then put the laptop back together and that should reset the BIOS, password and all.
Apr 27, 2011 | Dell Inspiron XPS M140 Notebook
Need drivers to run windows 98se on dell xps m140
Microsoft (and Dell) stopped supporting Windows 98 a few years ago -- it lasted for over TEN years! So, it is *NOT* likely that you will find drivers for any computer that was "designed for Windows 2000" or "designed for Windows XP" or "designed for Vista".
So, in general, it is a _bad_ idea to connect any computer running Windows 98 to the Internet -- Microsoft has issued many "security-fixes" in the 4 years after they stopped supporting Windows 98 and Windows ME.
Nov 23, 2009 | Dell Inspiron XPS M140 Notebook
Where are the memory slots on a dell xps m140 laptop?
One memory module, ('Stick') slot is located on the bottom of the laptop, in the Memory Compartment. (Has two Philips screws on the cover, and is located close to the battery release button)
The other memory module goes under the keyboard.
Here's how to replace them from Dell Support,
http://support.dell.com/support/edocs/systems/xps140M/en/sm/upgrades.htm#wp999869
Sep 02, 2009 | Dell Inspiron XPS M140 Notebook
Looking to install memory in XPS M140
Usually there is a latch at the bottom where the memory chips go. Sometimes they are situated under the keyboard...
Jul 06, 2009 | Dell Inspiron XPS M140 Notebook
Installation of memory sticks
The absolute best way to find out how and what memory you need is to go to www.crucial.com. They will automatically look at your computer online and let you know exactly the type of RAM and how many you can use..
Apr 19, 2009 | Dell Inspiron XPS M140 Notebook
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
XPS M140 Help Please
What tune up did you use exactly? Let me know this and I'll get back to you with what has happened.
Aug 24, 2008 | Dell Inspiron XPS M140 Notebook
Replace Memory
Link
click on the links on the page for removing dimm A
1. Preparing to work inside
2. Removing hinge cover
3. remove keyboard etc.
Aug 21, 2008 | Dell Inspiron XPS M140 Notebook
Dell Inspiron XPS M140 Notebook Logo
142 people viewed this question
Alun Cox
