Question about Microsoft Windows XP Professional
How do i remove the software counterfieng error in windows xp
  • ronraz2001 May 11, 2010
    plz tell what is the software, and whats is the error exactly
  • 565 Answers
Assuming that you have a legitimate copy of xp, try registering it at the microsoft. Look in your start menu for something that says "register windows." You can also go to the Microsoft Update website and let your computer download all the updates. One of those updates will be "microsoft genuine advantage". That should solve your problem, if not, go to Google and type in "microsoft genuine advantage diagnostic tool" and run that. If it comes up not genuine, click on "resolve" while connected to the internet. If that doesn't work, you may be a victim of software piracy. In other words, someone may have sold you a computer with a non genuine copy of windows. If that's the case, and you indeed are not the pirate, then you can call microsoft and plead your case. They will usually validate your copy if you convince them that you are the victim.
Posted on Feb 03, 2009
How to Load or Reload"HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
Try this one:
This document pertains to HP and Compaq Desktop PCs with Windows 7, Vista, and XP. An error appears that contains a filename ending with MSI. (MSI refers to the Windows Installer.) This error can appear while Windows is starting up or when a particular software program is opened. This error might appear after using a Registry Cleaner or Registry Fix tool.
See the following error examples. Your error might be slightly different, but it has a filename that refers to or ends with MSI.
The feature you are trying to use is on a network resource that is unavailable. Click OK to try again or enter an alternate path to a folder containing the installation package 'TrayApp.msi' in the box below.
'HPProductAssistant' the feature you are trying to use is on a CD-ROM or other removable disk that is not available.
Figure 1: Example of an MSI error
c01378399.gifUsing Recovery Manager to Restore Software and Drivers in Windows 7 HP Recovery Manager (Windows Vista)
  • HP application recovery process (Windows XP)
  • If errors persist, you can clean up the MSI registry entries by using Microsoft's automated solution. For more information, see Fix problems with programs that can't be installed or uninstalled (in English).
    Preventing MSI errors To prevent these errors from occurring, make sure that registry cleaning and spyware removal utilities do not remove files and registry entries associated with your software. Instead, if you no longer use a particular software title and want to remove all references from the registry, remove the software by using the Add or Remove Programs tool in Control Panel. The software uninstaller will remove the associated entries from the registry.
    Some products available for free on the Internet suggest that the registry needs regular maintenance or cleaning. However, use extreme caution when installing and using a registry cleaner. Many registry cleaners generate other MSI errors because they do not recognize valid registry entries and delete them. This can cause more MSI errors and prevent other programs from working.
    If you do decide to install a registry cleaner, be sure to research the product thoroughly, and then download and install programs only from software publishers that you trust .
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="" >
    NOTE:One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside the HP Web site.
    Jul 12, 2014 | HP Pavilion Computers & Internet
    How to load or to reload "HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
    Jul 12, 2014 | HP Computers & Internet
    I have a Plustek OpticFilm 7600i SE film scanner. Every time I try and load-up the setup disc, the set up install starts and then comes up with this error message: An error (-500 : 0x8004ace8) has...
    It is quite possible that there is another piece of software that is clashing with your Plustek OpticFilm scanner. It is hard to tell which software is having a clash. If you remove that software from your system you will obtain the desired results. I suspect the SP3 of Windows XP may be responsible for this because Microsoft has indicated that Windows XP SP3 is not for everyone. If you install Windows XP SP2 uninstalling XP SP3 your problem can definitely be rectified.
    Good Luck!
    Mar 10, 2011 | Plustek OpticFilm 7200 Film Scanner
    NTLDR is missing is displayed when i turn on the computer
    The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
    Get more help and information for Windows XP hope this helps you.
    Mar 01, 2011 | Microsoft Windows XP Professional
    Error message at start up. Running windows xp. HP Pavilion a700N PC desktop. The message is: This application has failed to start because hpzjrd01.dllwas not found. re-installing the applicationmay fix...
    To fix hpzjrd01.dll errors occurring due to corrupt or incomplete installation of HP printer software, uninstall your printer driver and reinstall it again.
    To ensure the HP printer software is completely uninstalled from your system, we recommend you either use the built-in Add or Remove Programs utility or use the help of a third-party uninstaller, such as Perfect Uninstaller.
    for more information and help click here hope this helps you.
    Thanks
    Michel
    Dec 18, 2010 | HP Pavilion A700N (PJ516AA) PC Desktop
    I have uninstalled a downloaded program but it also uninstalled two of my drives in windows xp drivers, it now shows error 41
    hi, i have a story to tell,,first time i got a pc for my son,, we install many games and softwares,,we didn't know that some of this games and softwares may corrupt some programs and even the windows..Today before we install any games and softwares we check the list of programs or wright on paper ,programs from "add remove programs" of our xp..If we install new game or software and became unstable or sometimes hanging,,better remove it from "add remove progams",,not uninstall the program..don't install any downladed software if you are not aware of that software,,
    Feb 16, 2010 | Microsoft Windows XP Professional
    Error: your computer maybe a victim of software counterfeiting".
    This error is because you are using a pirated windows not Original one. The only solution is that you need to purchase a new original windows.
    Sep 08, 2009 | Microsoft Windows XP Professional for PC
    How to solve free Window XP software counterfeiting? E-mail:faridahmedghazi@hotmail.com
    I think there is no Windows XP for free, if you buy Windows XP but got that error, microsoft will replace your Windows by showing your proof of purchase.
    but you can try this tool to remove that error.
    Jun 06, 2009 | Microsoft Windows XP Professional for PC
    That's a registry error.
    In order to remove this, either you need to manually download all the missing or corrupted files.You may reinstall the windows XP or if you wish you can google for certain registry fixers softwares like :-
    http://www.instant-registry-fixes.org/how-to-repair-windows-installer-error-1706/
    Any further help, let me know.
    Thanks.
    Jun 04, 2009 | Microsoft Windows XP Professional for PC
    Xp error message
    Try the following:
    1. Click Start > Run.
    2. Type regedit
    3. Click OK.
      Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
    4. Navigate to and delete the following entries:
      HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc2k5" = "C:\WINDOWS\SVIQ.EXE"
      HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Fun" = "C:\WINDOWS\system\Fun.exe"
      HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc" = "C:\WINDOWS\dc.exe"
      HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"run" = "C:\WINDOWS\system32\config\Win.exe"
      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\"Shell" = "Explorer.exe C:\WINDOWS\system32\WinSit.exe"
      HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load" = "C:\WINDOWS\inf\Other.exe"
    5. Exit the Registry Editor.
    Nov 10, 2007 | Microsoft Windows XP Home Edition
    Microsoft Windows XP Professional Logo
    105 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
