Question about Canon PowerShot A570 IS Digital Camera
Canon a570 battery fail - with any and all new batteries
I have a cannon a570 IS purchased less than a year ago. worked great for 6 months. now no batteries work - any brand/ new/ rechargeable...no change - get battery low message all the time - lets me take 1 picture and then i need to replace!
i see on the cnet message boards that others have the same problem...any advice?Ditto for me. After only about five months, I went through two battery chargers, numerous batteries, and a couple of chats with Canon tech support who suggested pulling out the batteries and the time battery, waiting 20 minutes, then putting it all back together (with fresh batteries) so it can reset itself, all to no avail. I also know someone else who has the same problem after only five months.
Of course... I never filled out the warranty card, nor do I have my original receipt.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Lets try a simple check/fix; clean the battery terminals of the camera. It may even be necessary to scrape them to expose fresh metal. This is in consideration of possible surface corrosion/oxidation of the camera's battery contacts. In some other instances, it may even be necessary to stretch or slightly bend these terminals to ensure that they provide positive if not more contact pressure.
Pls post back result(s). Good luck and thank you for using FixYa.
Posted on Feb 02, 2009
  • 679 Answers
You need to update the firmware of your camera.
  • rockfixya
    rockfixya Feb 02, 2009
    download firmware from>>
    http://chdk.wikia.com/wiki/A570_IS
    and here is a help, that how to update firmware>>
    http://chdk.wikia.com/wiki/CHDK
    Thanks
  • Canon Master
  • 13,433 Answers
Hi
Check and clean the battery contacts.
You can get a free repair estimate from www.advancecamera.com/repair
The issue is possibly the mainboard in the camera draining too much power, that will need the help of a professional camera repairer.
Thank you,
Ekse
I'm using a Canon PowerShot A570IS, and am getting only 20 to 30 photos from fully charged Sanyo AA HR6 2000mAh batteries. I'm using the Sanyo Ni-MH quick charger that was sold along with the...
Unfortunately, this is not unusual with rechargeable batteries. The best thing you can do with a rechargeable battery is to fully and completely discharge it, and then recharge it fully. After that, there's nothing else you can do except buy a new battery. You can get brand new, unbranded ones on eBay for a fraction of branded ones, and they work great. Just buy from a seller with a good reputation, and you can't lose. I usually buy multiples and never run out of battery power this way.
Feb 18, 2011 | Canon PowerShot A570 IS Digital Camera
Camera only takes 5 photos before dying
This new battery, if it is the exact type of battery recommended by the manufacturer then it is most likely not the battery. if you bought a similar battery it might be for even the minimum difference makes all the difference with digital cameras. for camera repair this company does a good job and you can even select your problem on their online quote. www.teleplancamerarepair.com
Jul 08, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Short battery life
Use the best name brand batteries you can find. Energizers and Duracell work best. Chance the size of your pictures to the smallest you can. At 300 X 300, you can still make 8 X 10 enlargements clearly. The larger the pic, the more power it takes to process it.
Aug 09, 2009 | Canon PowerShot A570 IS Digital Camera
Battery problem
Remove stain from batt. location , spray it WD40 inside batt. compartment then use NiMH batt. enelop white color
Jun 17, 2009 | Canon PowerShot A570 IS Digital Camera
Hmmm...... there might be a time battery that needs replacing. Look fore something like CR1220 or time battery. Pry it open and replace it with a battery of the same size.
Jan 05, 2009 | Canon PowerShot A570 IS Digital Camera
LG VX8550 will not power up
you should take the phone to a mobile service center and have them try to fix the phone for you....your mainboard may have to much corrosion on the mainboard.
Nov 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Problem of rechargable battery
The best way to tell if it is a battery problem would be to charge them fully then use the camera and see how long they keep working as compared to what their specs are (probably in your camera info). It is also possible that the charger is at fault, which can be tested by measuring the output of the charger with a meter, or check to make sure the charger is the proper one for those batteries ("quick" chargers may need special batteries, etc.). If your camera can use alkaline batteries of the same type, try new ones and see if it still says "low" -- if so then it could be the camera. Hope this helps. If not, check your camera website and try troubleshooting there.
Oct 23, 2008 | Canon PowerShot A570 IS Digital Camera
For some reason the camera won't turn on. We just bought it a few months ago, and it was working.Suddenly it stopped. We even changed the batteries. What happened? It is a Canaon Powershot A570 IS
This can be anything from a bad battery contact, to something that went defective on the circuit board. Just double check that you are inserting the batteries properly if it takes AA types.
You would be best off to call Canon's tech suport and arrange for warrenty service.
Jerry G.
Apr 19, 2008 | Cameras
Canon PowerShot A570 IS Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
