Question about HP Compaq Presario V2000 Notebook
Windows os when i am installing windows xp sp2 so the process of windpws file copying after root partition formatted is too slow
  • Ralph  Walekr
    Ralph Walekr May 11, 2010
    I do not understand your question.
    You should try the quick format, during the format process.
How to reformat my pc with windows xp professional service pack 2
If you have the original XP installation disk with SP2 just install it in your primary CD drive and then boot from the CD when prompted. You may have to enter your setup to change the boot sequence if your computer doesn't boot from the CD. I'd have to know what computer manufacturer and model to tell you how to enter setup, but assuming you have a legal version of Win XP SP2, it's as simple as booting from the disk, letting windows install the temporary files and it will then identify your drive and whether there are any partitions. At that point you select the partition if one is shown or it will tell you the disk size and that there currently is no partition and ask you if you want to create one. folow the prompts until you get to the format option. You can select either normal or fast NTSF format and let the installation process complete. You'll have to enter the key and do some other user input required things like your time zone etc, but that's about it.
Dec 12, 2010 | Microsoft Windows XP Professional
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
System crashed , no restore partition, origionall had xpsp1, have Dell reinstall Cd with xp sp2....will it have to be re activated?
Yes, but it will erase any personal data you have. Let me know if there is data to save and I will give more suggestions.
Apr 13, 2009 | Dell Inspiron 600M Notebook
Ntldr error on ibm intellistation z pro w/ xp pro
During the XP install, you will be given the chance to set up partitions on the drive. Blow them all out. Completely. Then recreate the partition and let XP install. I expect this will solve the nt loader issue. If, however, it does not, then use the recovery approach below to get the required loader files onto your boot partition.
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "d." This letter may be different on your computer.
    copy d:\i386\ntldr c:\
    copy d:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mar 04, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
LG E500 Notebook cant load OS
hi,
when you install the new os there are usually two options
1) to install a new os formating the partition ( which distroys all data on the partition)
2) install the os on existing partition without formating the parttion, i think you are choosing this option in order to avoid the above written error in this option choose use the directory other then already present
like if earlier directory was
c:\windows
put in
c:\windows_new_date
so that it don't have to rewrite the files in the same directory and the files are loaded onto a new directory
and when it will be installed it will give you the option to select the installtion you want to boot from.
Further Queries are welcome
Jan 19, 2009 | LG X-Note LM50 Notebook
Lost Acer eRecovery password on Acer Travelmate 2350
i bought a acer aspire 3six20 from my classmate but i forgot tto backup the erecovery.. when i instaler a new xp the logo in6b5df8b.jpg
Jan 25, 2008 | Acer TravelMate 2300 Notebook
Installing windows xp
Try first  to use hiden boot cd.With it u can see all files on hdd.When u see winxp files just delte.But i will not take responsibility couse sometimes xp wont boot up...
But i recomneded you to save all your data and format your pc.Make sure that the partition cd must be deltet befor u contiuing with formating ur pc like in this pics:
http://www.imagehost.ro/pict/3003390347268b3728923.jpg
Oct 29, 2007 | Microsoft Windows XP Home Edition
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
