Question about Motorola Mobility SLVR L7 Cellular Phone
Instrument got wet
I have Motorola L7. it went in the water hence my keypad is not functioning, please help...i tried drying in the sun but nothing happens..only few of the keys are working & not all...please help fast...
I had the same problem with my slvr.I removed the battery and took a hair dryer adnspent many hours slowly drying phone.Been working for two years now!
Posted on Feb 07, 2009
L7 keypad light, mic not working... please
at first ribon change and then mic pice or light ic chake
Oct 28, 2009 | Motorola Mobility SLVR L7 Cellular Phone
DEAD AFTER FLASHING
sounds like it got wet... go to the service veriz or tmob whatever it is they can retreeve your memory onto another phone
Jun 06, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Screen problems
hi im josh a mobile phne technician i cebu phils. Friend the problem is your phone is wet til right now im sure. Friend don't use alcohol to clean it will not cure instead it will intensify the problem. As my expertice in phone you need to use a thinner lacquer thinner for appliances and for paint. lacquer thinner is a substance that will dry easily and can enter in any slots of the part to push out the  water that can cause rust. and friend thinner will not leave any mark to make rust so it is the safest one. you try to disassemble your phone remove all plastic parts and  rubber parts coz the thinner may damage it. only the metal parts of the phone you sink it in the thinner for at leat 40 mins. then after mins. remove and let it dry under the sun or under the electric fan. for a long time about an hour or more.,then after you assemble the parts.then it will be back the same as new. don't use the battery it cann't be repaired.  good luck that solution is 90% sure and safe. please vote me so that i will know if i helped you.
Feb 23, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Instrument got wet
First of all, do not turn it on. this would make more damage. Take out the battery, and completely dry the phone before trying to use again.
Did you dry the phone completely? If not here is the procedure to take out all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Feb 02, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Motorola SLVR L7
please change ur ic
it is ic problem .
ic is the integreted circuit of mobile...
Jun 26, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Keypad light wont turn on
It is the problem of your ribbon flex that is connector..
If you have not a good hand you cant do it. Take it to a Motorola Repair Center.
I'm sure the phone will be full functional again.
May 19, 2008 | Motorola Mobility SLVR L7 Cellular Phone
My Z3 got wet...
can you send me a code so i can unlock my phone
Apr 25, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
L7 water damage
I dropped my phone in the toilet when it fell out of my back pocket. The best thing to do is dry it as well as possible and then leave it out to dry. I let my phone dry for approximately 2-4 weeks and now it's working again. I found this out after I went out and bought another phone. LRL from Texas.
Nov 17, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Sea water in my phone!
Hi, It may never work again BUT!!! Take the battery out, take the phone apart as much as possible and place the phone on a register vent with the fan switch set to ON or in front of a fan for about 3 or more days and try it again. water usually does not hurt electronics as long as there is no power to it and it is dry when you put power to it. If this even happens again, Get the battery out of it as soon as possible an DO NOT REPLACE IT OR TRY TO CHARGE IT until it is completely dry. Water and powered electronics do not get along in any way shape of form. Especially salt water. You will probably have to replace the phone. Your saved information may be on the sim card. Good Luck. kstfas
Sep 25, 2007 | Motorola Mobility SLVR L7 Cellular Phone
V3 got wet
sorry to say this but a wet phone is ruined. You will have to take it to a tech at your phone server. They will either repair it or you will have to get another one. Water and phones do not go together at all. Sux.
Aug 20, 2006 | Motorola Mobility RAZR V3
Motorola Mobility SLVR L7 Cellular Phone Logo
61 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
