Question about Freecom (24358) 160 GB Network Hard Drive
Freecom network drive corrupted
The drive worked ok, but not perfectly for a couple of years.
It was in a hot closet and when I tried to access it both via the network and via USB I get the following message when I click on the drive in My Computer. I also can't use the explore option.
F:\ is not accessible
The disk structure is corrupted and unreadable.
  • Jonathan Greenstein Feb 19, 2009
    I'm posting a solution to my problem as I think it might help others with similar problems.
    I spoke with a number of experts and they all basically said that the disk would need to be sent away for the data to be extracted. Freecom themselves told me to format the disk.
    I was about to dismantle the unit to extract the disk when I thought I would give it one final try. I plugged it into the USB socket of different laptop which happened to be running VISTA.
    It started working! I then plugged it back into my old Windows 2000 machine and it also worked. It has now been working perfectly for almost a month connected to a hub as a network drive.
    A software friend told me that what probably happened was the the disk configuration got corrupted and the VISTA software actually corrected it automatically as soon as it was connected to the USB socket!
    It may be a coincidence that the disk started working but this is the first time that I have seen any possible advantage to the VISTA operating system!
  • 413 Answers
Sounds like it needs re-formating.
You might try> http://www.freecom.com/ecSupport.asp
Look through there to see if they have a utility that can sort the problem out....
Or a FAQ section where there might be a bit of help with the problem...
These drives need to be in open air or they can overheat and stop working.
Right click on the F:\ ,click format.
Look to see if the details of the drive are in the window.
Capacity ? 150gb ? or something close.
File system NFTS ?
If these details are there you can format the disk again.
Posted on Jul 01, 2009
Invisible network hard disk
well, if you can Ping it, then the firewall is not likely going to be blocking it. Regardless, which product do you have ? The Silver Stone 2-drive NAS ? If yes, you should be using the FNS Assistant (FNSA)
The Freecom Network Storage Assistant helps you to locate your Freecom SilverStore 2-Drive NAS in your network. It can also be used to:
- quickly open the SilverStore 2-Drive NAS configuration website.
- configure the basic settings.
- mount shared network folders.
a) Start the FNS Assistant and select the device from the device list.
b) Go to "Web interface of your Freecom Network Storage device" for initial configuration
hope that helps.
Mar 31, 2014 | SMC Barricade g SMC2804WBRP-G Wireless...
Can't access freecom storage USB disk
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Dec 21, 2012 | Freecom network Media Center 500GB, Gb LAN...
Unable to connect to my computer
I would try it on another PC to see if it is the drive or your PC that is the problem.
Jan 04, 2010 | Freecom (24358) 160 GB Network Hard Drive
My computer has found new hardware for my freecom external storag
It should automatically allocate a drive letter to it. Go to windows explorer and hit F5 to refresh the display and you should see a new drive letter with the name of FREECOM next to it.
Oct 05, 2009 | Freecom (24358) 160 GB Network Hard Drive
My 250gb hard drive is not working
Assuming this external hard drie is powered via USB, you probably just need the drivers:
http://www.freecom.com/ecsupportdetail.asp?serie=Mobile+Hard+Drives&group=1148826&interface=1148827
Jul 01, 2009 | Freecom (24358) 160 GB Network Hard Drive
My 400gb freecom external hard drive wont detect on my laptop, I have tried it on another PC but nothing. The light comes on the hard drive but nothing else
if you try to go on-line and search for drivers and system software updates. if thisd doesnt solve the problem then try hardware such as cables
Feb 24, 2009 | Freecom (24358) 160 GB Network Hard Drive
Files need updating but we have nothing to update them from
Just a long shot but my corrupted Freecom disk started working problem after I simply plugged it into the USB port of a laptop running VISTA. Worth a try as VISTA has the ability to uncorrupt disk structures.
Jan 29, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Freecom 400gb Drive
Have you tried to connect those drive individually and checked if they get detected when stand-alone? If they get detected stand-alone, install the Freedom software happen. Cheers
May 23, 2007 | Freecom (24358) 160 GB Network Hard Drive
Freecom 160GB Hard drive not recognised
Drives do fail Nick. Is it powering up [power supply problem?] Plug it in and go to Start/Control Panel/Admin tools/computer management/storage/ removable storage and disk management. See if the disc is recognised there. If it is not, and if the disk is spinning Try putting it into the deep freeze overnight. Plugging in next morning and if it fires up get as much off as possible before it goes down again.
May 20, 2007 | Freecom (24358) 160 GB Network Hard Drive
Freecom (24358) 160 GB Network Hard Drive Logo
427 people viewed this question
Top Freecom Computers & Internet Experts
Greg Ulan
Trippy Tripp
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
