I recently bought an Indesit W43T fron loader and cannot get it to spin, does it have this feature ?
  • scimex1 Feb 03, 2009
    Thanks, there is no manual for this machine, i have searched the internet, but no success, can you suggest something
  • Washing Mach... Master
  • 3,463 Answers
All front loading washers have a spin feature, regardless of make.
It should tell you how to do a seperate spin in your user instructions..
If you find this and it still does not spin, then there is probably a fault on the washer.
Please rate my fixta solution.
Posted on Feb 02, 2009
My indesit W43T washing machine has got whole body electrified, what can I do ?
Hi. You have to check if is grounded properly first:
Plug with proper ground
Connecting wire ( does have the metal pin on it ? Have to have it or will do that to you all the time. If this is ok,something indside is shorted to ground. Could be rusty ground,bad connection. Or simply motor is getting shorted to the ground. Sometimes a little bit of water is leaking out and getting on components.
Apr 19, 2017 | Indesit Washing Machines
My INDESIT W43T washing machine problem is cannot start,water no come in and i check the door also no lock,i try to another stage,only pump water out system function.another stage no function.what should i...
I have index w43t. it makes some abnormal noise from drain pump and water is not drained. I opened the drain filter and found the noise came from the drain motor. How can i solve this problem?
Aug 02, 2010 | Indesit Washing Machines
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
Check the hose from the pump to the outlet, sometimes it can get blocked.
Make sure you can hear the pump working, you should be able to hear it running.
Hope this helps.
Jan 14, 2010 | Indesit Washing Machines
User manual
Apr 22, 2009 | Indesit W 123 Front Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
