Question about GE Energy Star WCVH6260F Front Load Washer
Washer is turning my white clothes gray
I bought our washing machine barely 3 years ago. For at least the past year, my white clothes have been turning gray in as little as 3-4 washings. I've stopped using bleach after hearing this can cause the dye in some clothes to come out. I've changed detergents. I've used hot water. I've used warm water. I only wash whites with whites. I don't know what else to try! I'm tired of my white clothes being ruined by washing them! Could this be a problem with the washer itself? HELP!
  • rkladder Apr 23, 2009
    I have the same problem with my whites. My blouses are dull and gray looking after 1 or 2 washs. Can some one please give advice on how to avoid this.
  • GE Master
  • 4,655 Answers
Oil from transmission is a good possibility. The machine is still young but sounds like you do a lot with the washer. Better have a friend that don't mind looking it over, make sure that's oil and go from there!
Posted on Feb 02, 2009
    New Friend:
My front loading Frigidaire washing machine keeps eating my clothes and then there is this flakey gray residue on the items it has chewed...help
Posted on Jun 17, 2013
I purchased the Kenmore Elite washer approximately five years ago. I have had no problems with it operating. However, since purchasing this washer I have ruined almost everything white I owned and avoid...
There has been many reports of complaints regarding this problem and it was found out that the gray spots on white clothing are caused by the fabric softener. The Kenmore Elite is a "highly efficient" machine that it uses very minimal amount water when washing and rinsing. The minimal use of water results in the fabric softener not being diluted completely and eventually makes gray spots on white clothing. The ridiculous solution to this problem, as Sears "advised" is not using fabric softener for white clothing. But you may also try putting the fabric softener in a small plastic bowl just enough to hold it and place it inside the machine prior to the final rinse. Using only the suggested amount of detergent and avoiding the use of detergent powder with speckles reduces the possibility spot occurrences in your while clothing.
Aug 27, 2010 | Kenmore Elite 45986 Front Load Washer
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
My kenmore washer front load is leaving stains that look like soap spots or grease (not black) on my dark colored clothes red blue green navy I don't use fabric softner and I use less than half of the...
periodically this has happened in a white sheet wash in my kenmore front loader series 417. we ran the washer empty with washer cleaner and blackish water was ejected from the pump. Another site suggests mildew under the drum . I am wondering if some oil from the unit is leaking in on a high spin cycle where the load is too full.
Oct 29, 2009 | Kenmore Washing Machines
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Dear carolesergy,
Welcome to fixya
You sad,My clothes get dingier ever week from using my washer especially the towels. They are now Grey and not white
1.Here are some ideas and INFO!
2.How old is your MAH5500B washer and did you buy it new?
3.Do you use HE High Efficient detergent?
4.Do you ONLY put the proper amount of detergent directed to be used by the manufacturer?
5.Using to much detergent will degrade the seal and eventually destroy the bearings.
Which will cause oil to leak out on your clothes and sometimes make gray stains on them !
6.Is there tiny gray oily pieces in the wash and on clothes?
7.Look closely at your rubber seal around the opening. Is this worn or deteriorating away slowly due to bleach or detergent? Is it a gray or black rubber?
Please have patients and bear with me, with all these questions I propose to you here!
I am searching with your eyes for things I have seen in the past about this model"
Here are some reasons this may also happen!
How large of a load can I wash in my Maytag Neptune washer?
* The tub can be loaded completely full with dry, unfolded clothes. However, do not pack the tub tightly. If the load is heavily
soiled it is very important not to overload the washer.
My whites are not as white as I’d like.What can I do?
* Wash white loads using the cotton/sturdy fabric selection. Select the hot wash/cold rinse temperature setting and put 3/4
cup of chlorine bleach in the bleach dispenser. The bleach will be dispensed in the final minutes of the wash providing for
optimal whitening. Maytag recommends a hot water wash temperature of 120-140° F (49°- 60° C).
Also:
*The lint filter in side the machine may be clogging with dirty lint!
*Which means you needed service!
I hope one of these solutions is the reason!
Let me know how you do!
Huuum
Please remember to leave a rating for me!
Oct 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Do I need to descale or rust treat my Washing Machine?
  • this is a common problem with aging kenmore washers (leaving coins in your pockets speeds it up).
  •  the basket is metal with a porcelain coating. the porcelain coating wears around the edge of the holes in the basket first, leaving bare metal.
  •  when the washer spins the centrifugal force pushes the clothes against the basket and a little into the holes. this leaves little rust rings on your clothes.
  • lumpy816 is correct in saying that your basket should be replaced. it does require a special tool, and the basket is expensive.
  •  in the mean time try to take the clothes out immediately after the washer stops spinning. and if you get desperate you can clean thee inside of the tub with a rust remover like LCR or a strong toilet bowl cleaner that removes rust.
Jun 30, 2008 | Kenmore 24032\24036 Top Load Washer
Lint marks left on clothing
hello are you washing new items new items tend to create more lint within the first few washes check all pockets to see if there is anything left in them there maybe to much wash action for the size and type of load try selecting a less aggressive wash cycle
Mar 10, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Bleach stains
try putting your washer on the highest boil wash this sometimes will stop any of these problems from accuiring again
Jun 12, 2006 | Hotpoint WMM39 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
1,862 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
