Question about Gateway 3550GZ Notebook
Centrex a/c keeps shutting off every 15 minutes ( split system)
Can anyone help me
my centrex split system ( model CTAR65GW), that i had installed in feb 06.
i am currently awaiting a call back from good guys, regarding the warranty.... or per haps lack there of since the compnay went bust...
more immediate, my problem is that the unit switches itself off every 15 minutes it also flashes the timer light,, this ll happens without any input or button pushing on my behalf
i have re set the remote........
but apart from that im not sure what i should be doing..
please help
  • macandanne Mar 03, 2009
    Mine is doing exactly the same. Turning off every 15 mins or so & it is driving me up the wall. The owners manual mentions nothing of this at all. HELP??? HELP??? HELP???
Centrex airconditioner
HI,
Can you please give the model no. so that i can give you the right parts.
Waiting for your reply.
Apr 08, 2008 | Heating & Cooling
Anyone know where I can get a fan motor for the indoor unit of my centrex CTAR65GW split system air conditioner. i think the motor may be generic for most of the cheaper split air conditioners. Denis
I buy alot of those motors through www.grainger.com
match up the hp, rpm, shaft size, mounting, voltage, etc... this can take a bit, but you will find a motor for partically anything there...
heatman101
Aug 11, 2010 | Heating & Cooling
I have a Centrex air keeps tripping breaker
The first thing I would check is the outdoor unit coil and see if it is restricted(dirty). If that is the case then you can wash it off with water(make sure you shut the power off to the unit first). If the outdoor coil is restricted and has little air flow thru it ,it can't get rid of the heat from the space and the compressor will draw over amperage and trip the breaker.
The next thing to check is if the outdoor fan is running. If the fan doesn't run it is the same as the restricted coil, it can't get rid of the heat from the coil. Check these things first then we can go from there! Thanks!!
Nov 22, 2009 | Heating & Cooling
To start, check your condencer fan and make sure the condenser is clean.After that you will need a technician with instruments. If the switching off is constant, after approx. every 15 min.it could be switching off on high pressure.
Feb 02, 2009 | Heating & Cooling
Centrex a/c playing up, in warranty but company bust??????
Pretty much you are out of luck. If you were my customer I would at least take that into consideration when billin. The contractor was responsible for the first year of labor, this is a nightmare for them also imagine if they have done lots of these.
Not blowing cold air
Sounds to me like your compressor is not operating, first check the filter to make sure its not pluged up, if thats not it, you will need a qualified service tech to come a diagnos it for you, but sounds to me like the compressor is bad, hope that helps
Jan 20, 2009 | Heating & Cooling
Centrex CTAR65GW reverse cycle air con. missing remote control -
Thanks for your response, but we finally found a universal remote through Andca Airconditioning in Rosebud, Victoria. It cost us $90 and worked a treat.
Thanks and regards
Wendy
Jan 07, 2009 | Heating & Cooling
Centrex split system air conditioner
I have a centrex split system which the inside unit is working but the outside one the motor is not working does anyone know why and where can i get parts from sice centrex no longer exists..
Nov 18, 2007 | Heating & Cooling
Gateway 3550GZ Notebook Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
