Cam won't show up in chat room....why? Settings are set right .cam work other wise.. but not detecting in yahoo chat rooms.why? .
Normal
0
See section B. Yahoo
Messenger in the info below to setup the Audio & Video.
Also send this to your family
and friends so they have their computer setup properly.
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://ca.messenger.yahoo.com/download/
) set it up as follows:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
NOTE: Your audio and
video should work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope
this helps. Bud
1st You download Webcam Driver.
Logitech webcam driver
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
I had a similar problem. The solution posted earlier did not work for me. Then I noticed - what I believe to be - the problem.
The device listed in the default webcam dialog box is Logitech 900 (not 9000). I simply typed in the extra zero at the end of the name in the box, saved the change, then restarted Yahoo! Messenger.
Voila! It worked.
Hope that helps you solve your issue, too.
camera doesn't work with yahoo messenger. I keep getting the message "Sorry, no camera detected on your system". Camera works otherwise. I can take pictures and videos,can open it on my desktop. but not with yahoo messenger.
same thing here, pissin me off.
Same same, looked everywhere for an answer, but still no dice.
Messenger does not give me the option in preferences, to select the Quickcam Pro 9000. It does not appear in the pop down box.
