Question about HTC Touch P3450 Smartphone
Any screen saver in HTC PDA? - HTC Touch P3450 Smartphone
Some time did not received and photo via blootooth
Posted on Feb 02, 2009
How do you take off the battery out of the HTC
Securely hold HTC One max facing down.
Slide the back cover lock down, and then lift the back cover from the side., replace battery then put cover back on
Aug 07, 2014 | Lenmar PDA Battery; 3.7V, Fits HTC Mogul,...
Reset
There are 2 modes for resetting, on the screen, and a hardware reset. I hope the following link works for you.
http://www.htc.com/www/support/htc-explorer/howto/91346.html
May 16, 2014 | HTC Explorer A310e Android 2.3 Unlocked...
Align screen problem on HTC P3650 Touch Cruise
try to hold the curser where ever it goes for some seconds after 3-4 tries ur device will start proceeding.
Sep 23, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Touchflo of HTC Touch 3G won't launch
Hi. TouchFlo is the special today plugin for the HTC devices, and as you realized, you can still use all functions of your PDA without. I think there is an error in the installation of TouchFlo (There can be a bunch of reasons, we have to know everything you did with your PDA in order to guess them), but there is a safe solution for that problem, you can backup all your personal data and software to your PC, then you can hard reset your PDA to its factory default settings. That way both your phone and the TouchFlo will work. In order to hard reset your PDA (after the backup of your personal data), you can follow the steps in this link: (http://www.hardreset.eu/htc_touch_diamond_hard_reset_soft_reset_en.html). Hope this helps.
May 27, 2009 | HTC Touch Diamond Smartphone
I have external GPS button in my HTC touch p3452 pda . . how to get get gps data from this ??
u need an external gps device bought separately and then trhu bluetooth u can communicate with this software in ur HTC , u have external bluetooth device or not
nowdays GPS is coming builtin so there is no need to purchase separate reciever but in ur PDA it is not built in
pls rate me WELL for info !
May 20, 2009 | HTC Touch P3452 Smartphone
Touch pro screen blank
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then then go to www.htc.com and upgrade ur ROM
Pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
It just losses power and turns off. when i restart sometimes it doesnt start (in this case i have to remove the battery and put it back again), sometimes it starts but the screen backround becomes red and...
just try this
when ur pda is switched off press Call and end key together and then press power button for like 5 sec a screen will appear asking u to format the pda pls confirm the action by pressing center button of the 4 way keys and then ur pda will be factory reset to the default OS , if it helps ur problem then tell me
other wise go and upgrade ur ROM from www.htc.com it will help u for sure basically it is a software issue
have u ever tried to update ur pda thru custom rom if yes then there is a bit checnge in the process pls let me know but u can try the reset thing it will work
pls rate me fixya if i fixed ur problem
Mar 04, 2009 | HTC Touch P3450 Smartphone
HTC: I get a white blank screen when I try to read or reply SMS
actually some png file is missing from the windows directory which is causing this problem try upgrading ur PDA software with the latest one available at www.htc.com it will help
and for the other guy check ur htc home plugin settings in today screen settings u can change ur clock to digits or u can also use SPB mobile shell its a nice software to completely change the look of ur pda jus google it or install Manila 2 D if u want further satisfaction i use it on 3450
Feb 12, 2009 | HTC Touch P3450 Smartphone
Backing up data from PDA with damanged screen.
u can sync ur data with pc using active sync. everything link contacts, schedule etc can be transferred to pc
Aug 13, 2007 | HTC S710 Smartphone
HTC Touch P3450 Smartphone Logo
420 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
