My washing machine doesnt start please help!! :s
I turn the washing machine on and and select the wash that i would like which is "quick 30" i set the tempurature to the highest setting and increase the spin cycle as i go to hit start the lights completley go and the washing machine turns of before it even starts the cycle please help it will be greatly appriciated
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
How to do a quick wash
You didnt state what machine you have but if your machine has a quick wash it will have a setting for that cycle every machine i delivered GE Maytag LG etc all had a quick wash setting on the dial if this doesnt help call manufacture to see if your machine has one good luck
Apr 22, 2016 | Washing Machines
How do i set the washing machine to do quick 30 minute washes
no way 5 hours . should never take more than 45 minutes ever
Mar 05, 2015 | Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
Takes ages to get through wash cycle
You should have a quick wash on your unit. By using a concentrated washing powder you can do your washing on quick wash mode which most manufacturers set to approximate 30 minutes. In a front loader most clothes can be washed on a quick cycle. Because of the way they wash.
Jul 26, 2011 | Washing Machines
LUMINA WM3011. Front Loader. I put in a load of washing, pushed start (quick cycle) then bad decision quickly opened door! Now cycle won't finish completely. Bring up error message of EO3 - don't know...
OK, I can't find anything on this machine for free. Do you have a user manual?
If not, try this. Unplug the machine, wait 30 seconds, plug the machine back in. At this point, I would think the machine would go back to a default setting. You should then be able to try to restart the cycle.
Good Luck, let me know how it goes.
Gary
Jan 15, 2011 | Washing Machines
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Wot is the best setting for a quick wash
If your washer is a Hotpoint WF430, then the quick wash programme is L.
This is a 30 minute, 30 degree wash.
Trust this is the information you are looking for.
Please rate my solution.
Thankyou.
Jan 19, 2010 | Hotpoint WF430 Front Load Washer
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
