My External Hard drive is not recognized and makes sound
Hi
My External laptop drive stopped suddenly. It was connected to my machine and the ahrd drive was on the table. One of the colleagues have to walk through the cables so she picked up the drive and put it in my hands and since then it stopped working. The light turns on green and then to a greenish red. The hard drive makes squeaking sound and stops making any sound within a minute. It is not recognized by the computer. I tried re-booting my laptop but it didn't help. I have my entire career related stuff in this drive. If it fails, I am destroyed. I need help. This is a WD 120GB. Please suggest.
Thanks
Siddarth
  • 1 more comment
  • siddarthmand Feb 02, 2009
    Robert,
    The drive is not dropped. It was moved. Thats it.
    Roshan,
    Any idea about how WD helps in the data recovery??
    Thanks for your help and avice
    Siddarth
  • Roberta Smith
    Roberta Smith May 11, 2010
    ok... first unplug the drive from any power source for about ten minutes.... reboot the computer and see if it will recogize it... i'm still a little uncertain... the drive is an external drive that plugs into your usb ?
  • Roberta Smith
    just so i get this right... the drive was dropped ?
    Robert
  • 14 Answers
Have you tried connecting your external to some other computer or OS, will the same problem occur?
Well, in thiscase the MOST effective way is to try some so-called data recovery software to see if you can find some data back. Recommend you have a try of Wondershare Data Recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem! Remember - Always make Backups of your precious data!
Posted on Jan 13, 2011
    Sergeant:
    Champion:
  • 271 Answers
These drives are very sensitive...i think you damaged it..contact WD to recover your lost data
Posted on Feb 02, 2009
The light on the hard drive is on but my laptop isnt recognizing that it is connected? I have no problems for the last 12 months then suddenly it stopped working
Have you try to use other cable or test it to other computer?. If the problem still the same then their is a chance that your external drive are already deffective. Try to visit a store catering hard disk recovery for any possible chances of recovery. Just a thought hope it helps thanks.
Sep 23, 2011 | Western Digital My Book Essential 1TB...
WD Mybook External Hard Drive
Sounds like it's gone bad. I recommend these guys, if it's recoverable at all. I used them on my last job and they came through with all the data: http://www.gillware.com/
Feb 18, 2010 | Seagate 160GB 3.5" External USB Drive 160...
I have a SimpleTech 320 GB external hard drive. It suddenly stopped appearing in My Computer. When I turn it on, it makes a repetitive sound that seems like a warning of some kind...what is it? It sounds...
Hello and welcome to the TSF. If the external drive has provisions for external power you'll need to plug that in, usb ports cannot power a 320 drive. If the drive has 2 usb plugs (one for additional power) you'll need them both plugged in, and I would suggest that the laptop should also be running off of external power rather than battery. If you disconnect the usb drive or any other usb device without first stopping the device then sometimes the usb ports will fail to recognize the device when it is plugged back in, a simple reboot should do the trick. You can also check in the device manager for any yellow exclamation marks on your usb host conrtoller and see if the driver for it is in need of an update.
Any drivers you need should be on simpletech's website, though normally you should not need any for a usb hdd. If the power cord/a/c adaptor is faulty or the hdd is loose in the enclosure(thus not making good contact) then you should pester simpletech to either replace the cord, a/c adaptor,or unit, and see if there are instructions on how to take apart the enclosure and reseat the drive/connections.
__________________
Nov 07, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
My hard drive suddenly started beeping and stopped working
Your drive has failed. to try to get back some of your items put the drive in the freezer for a day. the chill will make the heads condense enough for about 3 hours of use for emergency backup.
Nov 07, 2009 | Hitachi 500GB External USB 2.0 Hard Drive
Computer doesnt read the external hard drive anymore
It sounds like the hard drive head crashed when you pulled the power plug. Unfortunately if you can't get drive to be recognized, you won't even be able to run any diagnostics. You will have to take the drive to an authorized repair shop who will have to check the electronics to see if the head will respond. Unless you have data on your drive that you absolutely need, you will probably save a lot of money by replacing rather than repairing the drive.
Jul 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My laptop HP zd8000 doesn't recognize Seagate external hard drive
hi..the reason for your problem is your extenal
hard drive has been affected by viruses.The best
solution to this problem is scanning your hard drive.
once you scan it u will be free of viruses and your
laptop will be able to recognise your hard drive.
try it out..
thank u..
rate me..
Feb 10, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
Jan 08, 2009 | Maxtor OneTouch III 500 GB Hard Drive
Toshiba external Hard drive not working
I suggest to connect the harddrive straight to the computer as a slave disk, coz i think the casing power has been damaged. make sure u set its jumper as slave, the harddrive in the machine which contaoins windows should be the master.
Mar 11, 2008 | Computers & Internet
Computers & Internet Logo
827 people viewed this question
David Payne
David Payne
