Question about Hoover Refrigerators
Fridge - wiring diagram / thermostat connection
Somebody, a few weeks ago, ripped off a broken thermostat from my friend's fridge and then left all wires hanging and said that it can not be repaired (he is an idiot).
And I need to know which of the 7 wires that are sticking out there is for what ? 3 are OK (earth, Active and Neutral), but the other 4 are a puzzle :
- white and black with FEMALE 6.3 mm connector (resistance is 0.0 Ohm between them)
- 2 white with MALE 6.3 mm connector
I was not able to find a wiring diagram for this fridge (Hoover HE370TC) on internet
Thanks
Why won't it turn on?
Feel the compressor to see if it is getting warm or hot when you plug it into the power. If the compressor is cold like before plugging into a power outlet then let's try jumping the thermostat wires. What is the model number of the fridge?
APPLIANCE 911
Nov 24, 2015 | Refrigerators
No power in my fuel pump fuel relay for fuel pump
Get yourself a wiring diagram & study it & then
start testing the fuel circuit
How would you know whether you had power or
now power, to anything, working blindly?
You listen to what your told.
I wouldn't-- you may have changed a good fuel pump
I NEVER walk to any vehicle without a wiring diagram
How would you learn the system & the circuits, without one?
Oct 16, 2014 | Cars & Trucks
Not cooling
either your heating element for auto defrost is broken or your thermostat is is broken
Dec 09, 2013 | Frigidaire Refrigerators
NEED A WIRING DIAGRAM
go to the junk yard with a camera take a pic of the wiring harness then go back an match them up
Feb 07, 2013 | Cars & Trucks
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
May 12, 2010 | Refrigerators
Zanussi zx99/5 not working ,lights still working but freezer defrosting and fridge getting warmer
sounds like the thermostat inside the fridge has gone.
The information I have provided is a guide and is not directly related to the make and model of the appliance brand you have but seems to cover the majority of household fridge freezers I have come accross. There is a dial inside the fridge usually up on the right side wall of the fridg where the light is. It is usual for the thermostat unit to be inside the plastic housing behind the dial. It is easy to replace the thermostat because I have done it myself and it worked. I am not an expert so if I can do it then anybody could. the unit is usually a standard replacement unit which costs roughly £20.00 available from fridge freezer repair shops. I got my replacement from Sale Appliances, Victoria Avenue, Southend-on-Sea, Essex. The unit comes with the thermometer type wire which fixes to the back of the fridge - inside that is- already attatched to it and all you need to do is remove the screw holding the housing in place (unplug from mains first of course), remove bulb, prise off the plastic housing to reveal thermostat unit, take some detailed pictures of how the wires are attatched or take detailed notes and diagrams, pull off the eelectical connectors (may need a pair of pliers to help, but must be gentle so as not to rip wires out of the connectors), put in new thermostat and rewire as it was before. You will not have to literally rewire the thing but simply slide the wired connectors onto the correct place. The connections are numbered both on the old unit as well as the new unit. Dont worry if the connectors on the rear of the new unit is different to the old one so long as you connect the wires to the same number it wont matter where that connector is located e.g. number two always fixes to the number two marked on the unit, number 3 to numbr 3 etc.
Aug 08, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
We have a heater whose thermostat switches broke a week ago. Am desperately looking for a wiring diagram for it. It says Radel thermostat on it. I would like to set it to be constantly on, whenever we...
usually the thermostat has only two terminal wire, it acts like a lamp switch, will open and close according to the temp setting. L1 usually pass trough the switch and L2 directly connected to the load or heater.
Jun 07, 2009 | Heating & Cooling
Refrigerators Logo
4,736 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
