Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage wall mount
My wall mount of my garage won't open most of the time its llit up red but sometimes it won't open or close, i can push and push it will blink the light off and on, but won't budge. now my garage opener works perfectly for outside.
  • calcityjoe Feb 09, 2009
    My remotes all work but when I push the pushbotton I have on the wall the door only goes up about 3 inches and stops.When I repush the botton it goes back down.
  • 30 Answers
This might be a easy fix but not sure two thigns I would try is check to make sure you don't have a lock switch on your wall control and if you do make sure its off. That locks out the remotes but oddly they go bad and sometimes just do really odd things. The other thing is check the wire to the wall control make sure theres no cuts or staples in it
Posted on Feb 10, 2009
Liftmaster 1255lm garage door opener
It sounds like a problem with the infrared safety beams, either they are not working, are misaligned (someone might have kicked/bumped into one), or I even had one that didn't work because there was too many cobwebs/dust covering one of the lenses.
Feb 09, 2014 | liftmaster Building Materials
My Craftsman garage door will not close, only a few inches at a time
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Dec 19, 2013 | Building Materials
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Must hold wall unit to close garage door...
there is an error in the system. most likely The safety beams (mounted on the track near the floor) are out of alignment and the LED light should be blinking. The garage door opener will not let the door close if the beams are misaligned. Realign them and the LEDs on the beam or on the operator will stay on. you should be able close the door now with one push.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
67 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
