Question about Fuji FinePix A345 Digital Camera
A345 won't turn on
My A345 won't turn on when I press the power button, even after I installed fresh batteriesl.   When I press the power button I get a momentary flash of the green "on" LED and then nothing.  Right before the camera quit I was erasing a few shots from  my filled up XD card.   I've had this camera for about 3 years and it has always been completely reliable until today.  It hasn't been dropped or abused.  Can anyone out there suggest possible fixes or solutions to this problem?   Many thanks to all who reply.
  • 3 more comments
  • rbprod Feb 02, 2009
    Thanks Dotball for your reply.  The batteries are NEW alkaline.  I pulled out the xD card like you suggested and the camera still won't start - still getting the same momentary flash of the green LED upon pressing the power button and then nothing.  I hope I can fix my A345 because it's still useful to me.  Any other suggestions?   Thanks again.
    RBprod
  • rbprod Feb 03, 2009
    Thanks again Dotball.  I've tried everything and still no response.  I guess that the patient is dead and probably not worth the cost of reviving, so time for a new camera, when I can afford it.    RIP A345, you were a great introduction for me into digital photography.
    Dear Semitone:   Thanks so much!   This is the solution!!  Just when I had given up you've provided the answer. Thanks again!
    Fixya is great :  the power of everyone helping everyone.
  • pakam99 May 13, 2009
    is the L shaped lug the one that is actually on the cover that opens? or is it that little hole on the left of the PUSH TO EJECT sticker?
  • Anonymous May 19, 2009
    The match stick did the trick....Thanks heaps...Keith
    So frustrating
I experienced exactly the same problem with my A345. Check for a small L shaped lug on the inside of the battery cover which should operate an interlock switch located in the recess next to the PUSH TO EJECT label. The lug on my camera had snapped off, although this wasn't obvious until I looked at the illustrations on pages 10 and 11 of the owner manual.
My quick fix was to wedge a piece of matchstick into the recess to lock the switch in its operational position. The purpose of the switch seems to be to ensure that the camera is switched off when the cover is open, but as the battery connection relies on the cover being closed, this is liable to be the case anyway. The only possible risk would seem to be if one attempted to remove the memory card with the camera switched on while being run from an external power supply.
Posted on Feb 03, 2009
    Novelist:
    Scholar:
  • 64 Answers
When you say you "installed fresh batteries" are they NEW alkaline batteries or newly recharged ones.
When troubleshooting, forget the rechargables. Put in some NEW batteries and remove the XD memory card completely and try and start the camera.
This may not be a solution, but let us know how it went and we'll work on it.
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 02, 2009
  • Dot Ball
    Dot Ball Feb 03, 2009
    RBprod, I've been doing some digging on this as after I had a think about it, it's stumped me.
    I've found nothing.
    I do have one last suggestion to sus' out the problem - as you go to start the camera, LIGHTLY assist the lens's cover to open and help the lens come out.
    If this works, it could be just a matter of a grease or lubricant (which is used in the helicoid threads in the lens assembly) may have run into a place they are not supposed to be and when the grease cools, it hardens and becomes sticky, which can restrict the lens from moving to a running position.
    If this is the case, and if this does not fix the problem, I would suggest, although the camera is fixable, it may not be 'economically' fixable and therefore you may well be better to look for a new replacement.
    It may be an old faithful, but at 4mpixels, you can get a camera of better quality for around $100-130. (yes, still a lot of money, but likely to be as much as your repairs to the old camera).
    Have you tried turning the camera on while in different modes; it would be good to get at least a menu on the screen where you can go to the "Reset Defaults" option and see if the camera resets.
    Sorry I'm unable to fix your problem, but hope we've refined to options to user servicable or not.
    Good luck with it - I'd like to know how it goes.
  • Dot Ball
    Dot Ball Feb 04, 2009
    Arghh, I can't believe I missed that - I have 2 cameras here with the same problem, broken switch pins on the card cover.
    A common issue with Fuji cameras.
    Semitone, you're spot on - I couldn't see the forrest for the trees.
    Good work.
Thanx Fixya. my Fujifilm Finepix A345 now working fine after lying abandoned for last 9 months, the matchstick solution worked a treat! great site Fixya.
Posted on Jul 20, 2011
Microphone PG58 won't turn on, it has a blinking red light when I push the power button
Your circuit board could be bad, but i would pull out the circuit board and spray contact cleaner onto the button, let it dry a few minutes and connect the battery and press that button quiet a few times and see if that fixes the problem.
Dec 06, 2012 | Shure PG58 Professional Microphone
Childlock flashing unable start machine
Hi there, without some details of the make and model of your machine I can't tell you what buttons to press to perform a reset of the machine, however, this is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up. Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Aug 08, 2011 | Washing Machines
After a power outage, the lid is locked and won't open. I tried running a new cycle but won't run either. Any suggestions. Thanks, Jan
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Jul 11, 2011 | Washing Machines
My camera wont switch on
Make sure or Check out following thing :-
1) Direction of your battery might be wrong, Check out and put it again.
2) Load new or fully charged battery.
3) clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
4) Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix A345 Digital Camera
Reset timer on jvc dla g150c projectorlamp
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
button.
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
Sep 30, 2009 | JVC DLA-G150CL Multimedia Projector
Finepix a345 will not switch on
Does it power up in playback mode? If you can view pictures try switching over to camera mode and see if the lense will extend. if not then your lens is possibly stuck. possible solution in "THE ONLY WAY I KNOW HOW..." In my tips n tricks section. Also is my email if you want some pictures of an A345 opened up. Cheers.
Apr 28, 2009 | Fuji FinePix A345 Digital Camera
Wii balance board: i press the power button but nothing happens
Ensure you have fresh AA batteries installed. Ensure that Wii Fit (or any other Balance Board using game) is fully started before pressing the power button.
And, at the risk of sounding silly, ensure that the button is facing away from the TV.
Dec 30, 2008 | Nintendo Wii Fit for Wii
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Suddenly turning off...
    all figured out,,,,the shutter button is too close to the shut off button,its happened to me many times ,next time it happns try to catch yourself and see which button you pressed,,guaranteed!!! it sucks
    Apr 20, 2008 | Fuji FinePix A345 Digital Camera
    No power at all
    If you're sure the batts are fresh, check for corrosion on the battery contacts. Hold the on-button for at least 5 seconds. If still nothing it's probably a blown fuse. Check with us for prices: www.crystalcamera.com
    Dec 16, 2006 | Fuji FinePix A345 Digital Camera
    Fuji FinePix A345 Digital Camera Logo
    345 people viewed this question
    Top Fuji Cameras Experts
    Greg Cann
    Greg Cann
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
