Question about Pyramid PB779X Car Audio Amplifier
Need new RCA jack
My rca jack broke off of the board and I cant sodder it back on. How can I get that part?
    Novelist:
  • 68 Answers
Hello mixedkid43, you can try mouser.com or partsexpress.com and you should be ablle to find a replacement for it if you have'nt allready since this is an old post. I had the same problem on the same amp but I was able to use some jumper wire to fix the problem. I do amp repair for a living and also collect amps. Regardless what people say about this amp it does do 125 watts rms a channel at 4 ohms and maybe 250 watts a channel at 2 ohms. But at 2 ohms I think I got 200 watts rms a channel doing some calculations with it hooked up and taking voltage readings at different points durring opperation. So this amp is not bad at all. I bridged it to 2 10 inch PheonixGold Ryval V10S and it hit pretty damn hard, very surprised. Good luck
Posted on May 12, 2009
    Scholar:
  • 125 Answers
Well you can take it to sound repair company which will void any warranty or send it into the manufacturer but for the price of that you can get a new amp at wholesale dealer cost at this address
www.godspeedaudioheaven.com
Posted on Feb 04, 2009
Amp comes on but music plays for 30 seconds then crazy feed back noise.one of rca jacks feels loose are they replaceable
Yes they are can be replaced. If you meant the RCA female sockets on the amp then it needs that the amp is taken out and the RCA terminals soldered -- it can be poor joints. If not you can de-solder and change with a new one.
If this is the RCA main socket then the wire can be **** off and a new RCA jack of good quality can be soldered, taking care to keep the shield and main line with a good solder point.
Feb 05, 2011 | Phoenix Gold Tantrum 600.4 Car Audio...
I have a RF punch 401s 1200 watts and the RCAs broke off the mother board what do i do to fix it
If you have a soldering iron simply epoxy the jack down to the board and then take some wire and solder rthe center conductor of the RCA jack and the other end would go to the trace on the PCB. Do the same for the ground connection.
Jan 26, 2010 | Rockford Fosgate Punch 401S Car Audio...
Broke rca jack
You can buy replacement panel mount RCA (phono) jacks directly from your local radio shack if you have one, or on www.radioshack.com a 4 pack is less than 5 bucks, then you just have to have someone who can solder pretty well and TADA!! new plug in the amp.
Apr 01, 2009 | Kenwood KAC-728S Car Audio Amplifier
Broken RCA / phono jack - where to find new part?
You can buy Panel mount RCA (Phono) jacks at Radioshack, I think a 4 pack is less than 5 bucks, That should take care of your problem.
Good Luck,
Stay Classy
B.
Mar 03, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Rca jack is broke and i was needing a nother one
You may be able to get one from radio shack or a similar electronic hobby store. However you will have to open the amplifier up and solder the new jack in.
If i am not mistaken this amplifier also has a Hi-level input and you can just use that if you have the harness for that connection, you can put rca ends on it and connect it that way.
Feb 24, 2009 | Pioneer GM-5000T Car Audio Amplifier
Audiobahn amp help...
You have a Direct Short in the System Between the Head Unit and the Amp. Check the Ground on the Amp and then Check all the Wires behind the Stereo and the Common Ground There. You could even have a Spot in the New RCA Cables that is Touching Metal Somewhere. Please Rate My Response! Thanks!
Feb 09, 2009 | AudioBahn A2002T Car Audio Amplifier
Broke ******** in amp input
If the center conductor of the RCA plug broke of inside the RCA jack of the amplifier, you may be able to push it out from the back. If that's not possible, you may have to remove the jack from the board, disassemble it and then push the center conductor out. If you send me a photo of the jack, I may be able to offer more suggestions.
babin_perry@yahoo.com
Aug 09, 2008 | Sony Car Audio & Video
RCA INPUT JACKS
did it work well before?is it new? try moving the rca's and se if you hear any thing?
Jun 30, 2007 | MA Audio HK802SX Car Audio Amplifier
RCA inputs bad
If you got the exact same ones, you should be able to simply pit them back into the same holes. if you did not get the same ones, look at the open holes, two should be connected together, and two are separate. Hook the two that are connected together to the ground part of the jacks, and the middle connections of the jack to the other two holes. if this does not make any since, send a picture of the jacks and the board so we can look at it for you. Good Luck
Jun 19, 2007 | Alpine MRD-M1000 Car Audio Amplifier
Pyramid PB779X Car Audio Amplifier Logo
64 people viewed this question
Top Pyramid Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Alan Timperley
Alan Timperley
we_sims2
Level 1 Expert
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
