Question about IBM ThinkPad A21m 2628 Notebook
Floppy Drive not working
IBM A21m 2628, seems like it doesn't recognize the floppy drive , I insert a floppy asks to format then says unable to do it , the disks work fine on desktop
  • 2 more comments
  • wireman109 Feb 02, 2009
    it use to work just lately i don't use the labtop very often just to transfer info
    i checked the disks for that their unlocked , doesnt matter to me if i format it that means they'll work which is all i would like , by the way thanks
    oh tried updating driver says best one is on already
    you can remove the dr ,i've done a CPU removal and main board in one other one never did get it to work ,there's a fair mount of detail work to remove a floppy it's not like a cd drive
    Genius:
  • IBM Master
  • 1,102 Answers
Update your driver
when this problem start
Posted on Feb 02, 2009
  • 1 more comment
  • DEKR
    DEKR Feb 02, 2009
    it recognizes or it would'nt ask to format
    it is probably on write protect take it off write protect then insert again
    you really don't want to format it
    can you remove the drive from laptop
  • DEKR
    DEKR Feb 02, 2009
    i am going to look into this for you and i'll be back on tomorrow at 10 am it's now 1:30 am
    could be a couple things
  • DEKR
    DEKR Feb 02, 2009
    You may need to clean floppy drive
    they won't work if any dust is there blocking it from reading correctly
    also if you have floppy on write protect
    remove it
I have lost my floppy drive driver UF0002, I like to have that back so I can use my external floppy drive
You should not have to have a floppy disk driver as the machine (IBM format) recognizes the floppy drive upon boot up. Go into your BIOS setup and be sure that the floppy drive is turned on. It is always recognized as Drive A: or Drive B: Those two designations is reserved for floppy drives in the Basic Input Output System, reguardless if your machine came with an attached FloppyDrive.
Jan 11, 2011 | NEC (UF0002S-107) External Floppy Drive
I have an IBM External USB Floppy Disk Drive that I'm trying to use to access some old files on floppies. Do I need special software to be able to use this? Or...can you tell me how to make it work? I'm...
this device is plug and play does not need any type of configuration basically you plug the device and the server (PC) would usually recognize it as the "A" unit
Aug 16, 2010 | IBM USB Portable Diskette Drive (05K9276)...
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
ThinkPad A21m type 2628
This is usually caused by one of three items.
1. The cdrom drive is failing
2. The hard drive is failing (it may say hdd 0)
3. The interface to those two items is failing
Consult your seller ASAP and check that he would accept a return. If it was bought "as is" then your are out of luck. So sorry for the bad news
Aug 12, 2009 | IBM ThinkPad A21m 2628 Notebook
I need supervisor password
ok so first you get a hammer and the you smash that ho but before you smash it **** on it that will help alot hope you get that shi+ fixed
Mar 09, 2009 | IBM ThinkPad A21m 2628 Notebook
Ibm thinkpad A21m 2628 floppy dr not working
Take a can or air and blow a little bit into the drive to make sure dust is not in there. Then use good known floppy disks to see if it reads at that point. If it still doesn't read then the floppy drive is bad and will need to be replaced.
Feb 02, 2009 | IBM ThinkPad A21m 2628 Notebook
Floppy drive not recognize floppy
it is possible the floppy has been corrupted or it was formated under a diferent OS.
so you must format it to be able to use it with your OS.
Jan 14, 2009 | NexxTech USB External Floppy Drive (NEFD2)...
Installing new Hard Drive Problems
i suspect you need both because the cd is not a bootable one. download a win 98 boot disk from www.bootdisks.com it will allow you to boot to dos.... then you change to the cd rom drive letter.. usually D: ... tho sometimes even X: and then type setup... that should start the restore.
Robert
Sep 11, 2008 | IBM ThinkPad A21m 2628 Notebook
Can not get new plug and play usb floppy drive to recognize floppy disks.
Did it work before?
If yes, then it died.
If no, then replace it.
Mar 16, 2008 | Computers & Internet
A21m Irritating Noise
Is the sound constant?
Does it start as soon as you turn it on, or only when it's booted all the way up?
It sounds to me like a drive going out. Probably not the A: drive (by that I assume you mean a floppy drive), as those only turn when a disk is inserted. I'd guess it's the hard drive. However, that is only a guess - I can't give you more without more information. Regardless, if you don't feel comfortable opening the case, you'll have to take it to someone who does. Any experienced tech should be able to listen to it, and if it is the hard drive they will know that just from the sound.
-Dyllan
Jan 09, 2008 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
98 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
