Question about HP Compaq nx6110 PC Laptop
Hp compaq nx6110 power-on password
Hi! bunnydawg,
This is a reply to your clarification request.
It is not the operating system that is asking me the password. The computer request the password at power-on before the operating system loads. At power-on, It gives an option of F10 and F12 which both lead to cmos setup but require a power-on password to procceed any further. Can you help?
Regards,
Thawi
  • 1 more comment
  • thawi Feb 02, 2009
    I got the laptop from CBS. You can check out their site: www.cbs.ls
    But hey, thanks for the update. I dont have the laptop with me right now but I will try to tap the F8 as i boot up. I'll keep you updated.
  • consultjasb May 11, 2010
    You may want to search for bios utilities; some claim they can reset bios passwords. But bios passwords on laptops are another animal and bios passwords on many laptops are two level. If it's just a bios password they may help you, but if its a two-level bios password set on the hard drive, they can usually not resettable with software (OEMs theft control).
    Contact me (consult@jasb.com) with a picture of the screen at point of password request (probably need to us camera) and I'll try to help you further.
  • Roberta Smith
    Roberta Smith May 11, 2010
    where did you get the laptop.... hp puts a password on the bios but that is normal... ... tap f8 as you boot up and try last known good configuration.
I need administrator password for compaq nx6110
1.) Unplug AC, take out the main battery.
2.) Take out /disconnect the RTC (real time clock) battery for app. half an hour (the period of 5 min as specified in the MSG normally is not long enough).
3.) Plug in the AC adapter (batteries still removed); computer should boot automatically, if not use the power button.
4.) The machine will boot and show the 162-error-msg "system options not set". Use F1 to save the settings.
5.) Shut down the computer and disconnect AC power again.
6.) Re-connect the RTC-battery.
7.) Install the battery pack(s).
8.) Restart the computer.
Aug 11, 2011 | HP Compaq nx6110 PC Laptop
I am updating a freinds computer Compaq nx6110 note book , I am having a difficult tiime finding the driver for the ethernet controller. I have been to hp drivers page and still can't find this driver...
Since you don't clarify your op.system I suggest you this official link for selecting your op. system and download the proper drivers.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 04, 2011 | HP Compaq nx6110 PC Laptop
Power on password has been changed can't get in to laptop (compaq nx6110) Thanks for any advice
try taking out the cmos battery and putting it in again, that should reset the system password
>it is the big watch like battery inside the laptop
Oct 29, 2010 | HP Compaq nx6110 Notebook
When I switch the laptop on it says power on password
It seems you entered a Power ON password, If you remember please enter it or if not then you need to visit nearest Service Provider.
You can try Enter when it ask for the password. Or if possible Go to BIOS and disable the Power On password.
Sep 23, 2010 | HP Compaq nx6110 PC Laptop
Power-on password forgotten! How can the computer be started?
The Power on Password is set from the BIOS configuration. Ask that person who borrowed your Compaq for the password. Once you have this password, you can enter the BIOS configuration and remove/disable this password.
Depending how old you Compaq is, removing the BIOS battery and main battery for 15+ mins may remove this password and restore the BIOS to the factory default (insert both batteries again) and configure the BIOS Date and Time etc.
BUT if the the password is stored on an EEPROM chip then removing will not fix this problem. There are no backdoor passwords available.
Nov 19, 2009 | HP Compaq nx6110 PC Laptop
HOW CAN I REMOVE A POWER ON PASSWORD ON NX6110
Do u know the Power on Password? if yes, Go into the bios tapping the f10 key and Go to advance aoptions. There you woul find the options to Enable and Disable Power on passwords.
Regards
Naveen
Oct 10, 2009 | HP Compaq nx6110 Notebook
Hp nx 6110 a power-on-password
Hi, try this:
- unplug from mains
- remove laptop battery
- remove real-time clock (CMOS) battery.
- wait 5 minutes
- replace the RTC battery and then
plug in - without the laptop battery.
The laptop battery cannot be present
when you remove the RTC battery
and shouldn't be there when you power on.
Try
Mar 31, 2009 | HP Compaq nx6110 Notebook
I want to download hp compaq nx6110 drivers
Click here to download your drivers.
Just select your operating system and download the drivers.
Do not forget to rate !
Thankx
Mar 04, 2009 | HP Compaq nx6110 PC Laptop
Resetting the "Power On" password
Hi.
Power off laptop. Disconnect mains pack. Remove battery pack. Wait 30 sec. Connect just mains adaptor. Press power on button. press f10 for bios settings. Your passwords are now cleared
Nov 03, 2008 | HP Compaq nx6110 Notebook
Hard disk password has been loacked
Hi ,
there is no any soluction for reseting HDD bay password .u should reset password when u know old password .bcoz this is hardware password ......if u want to reset any other password like Startup just unpluged battery from motherboard & also disconnect laptop battery & press power button for 30 sec.u get Reset COMS ......
if this information is useful for u please Rate me .......
Jun 14, 2008 | HP Compaq nx6110 Notebook
HP Compaq nx6110 PC Laptop Logo
292 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
