Question about Linksys Wireless-G Broadband Router
Linsys router not working with Dsl modem error 321
My linksys router wrt5462, keeps giveing me an error code 321. I have used different cables and still get the same error...Also, it was working
a week ago, and now just quit....I have restored windows visa to an earlier date, but that did not help
  • 6 more comments
  • Paul Vernon Feb 02, 2009
    well, I get the error code when I try to re install the linksys software
    that came with the router....also when I let windows try to diagnose
    the problem, it says a cable is unpluged...thanks for you help
    will try again later.....will try a different cable....modem to computer
    works great....just when I put the router in between...I can't get on
    net...Thank you VEDHICK...I will do reset later after work and
    will follow instructions exactly
  • Paul Vernon Feb 03, 2009
    well, I tried the fix again...I still cant get internet to come up
    This all was working a week ago....I turned off the computer and
    router for 4 has not worked since...nothing was installed
    in that time I do not know what has happened
    still not working....I must be missing something simple
    thanks for any and all help
    I would really like the router to work again
  • Paul Vernon Feb 06, 2009
    ok please clear this up...I go to run and
    type ipconfig or do i type cmd prompt first
    i must have done something wrong...Thanks
    I cannot get a browser to open to the
  • bettyboop278 Feb 14, 2009
    Just set up a new router, first was getting error 322, that resolved itself. Now getting error 321 about ethernet cable. Used brand new ethernet cable I just bought and still getting same message. HELP!!!
  • Paul Vernon Feb 15, 2009
    I finally figured out my problem was in network connector on
    motherboard...I installed a ethernet card and used it and
    everything works perfect...I had checked all the cables and done
    everything else...thanks to all who helped me
  • Ved Pradhan May 11, 2010
    hi can you let me know when you get this error code 321?for example when you browse internet or while opening a particular application.
  • 141 Answers
If your problem is not yet resolved try calling Linksys Tech support. If they cannot help you try this
Posted on Feb 15, 2009
  • 54 Answers
Thank you for the clarification,
u need to perform the following steps:
1)donot use the cd for the setup.take the cd out from the computer
2)reset the router(if you look at the back of the linksys router you will see there is a small hole which contains the reset button,hold down the reset button while the router is on,once the time period of 30 sec is over turn off the router,turn it back on after 60 sec.
3)check the cables between your modem,computer and router.
4)the correct cables sequence should be following,there would be a cable going from you internet service provider modem to the back of the router(the post should be the one that is labelled internet or dsl) and there should be another ethernet(yellow/grey colored cable going from ports 1,2,3 and 4 )cable going to the back of the computer make sure the cables are plugged in properly
5)turn of the modem,router and computer,in a sequence that is given,modem----router----computer.
6)wait for 2 mins and then turn on modem wait for the light to be steady and then turn on the router wait for the lights to be steady and then at last turn the computer.
Hope this steps fixes your problem..
Posted on Feb 02, 2009
  • Ved Pradhan Feb 02, 2009
    sure let me kno if it is resolved.....vedhick
  • Ved Pradhan Feb 05, 2009
    as you told me the computer works with modem,the problem will be with the router,
    when all the devices are connected,double click on ie and then put and check if it opens the linksys page,
    if it doesnot open the linksys page,then go to run,cmd prompt and type ipconfig and hit enter,
    checked the ip address and default gateway,then type the default gateway if it is different from in the
    address box of the internet explorer,
    it should open the router page,user name is blank and password is admin,
    then go to the tab that says status and checked under the sub-category router
    and see the internet cofiguration type and check it it has numbeers written besides it or it is all zeros,
    if it is zeros then the router is not able to take the settings from your isp we need to setup the router manually..
    do these steps and let me know..
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
I keep getting an error message when i set my router up
The LAN cable maybe faulty, try a different LAN cable.
Jan 04, 2010 | Linksys WRT120N Router
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem:
Setting up a Linksys WRT160N Wireless Router:
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Apr 09, 2009 | Linksys WRT160N Wireless Router
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 17, 2009 | Linksys Wireless-G Broadband Router
Cannot connect to internet Model WRT54GS
I would like to know who is your internet service provider and would like to check if the router is configured with your ISP modem.
To configure for different ISPs here is the link
The links are there for setting up with DSL as well as cable modem. Do let me know if its working or not.
Thank you
Jan 06, 2009 | Linksys Wireless-G Broadband Router
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect to modem
if you know the cables are connected and not faulty, then it could be the fact that the network card itself is dissabled, so right click on the network icon in your taskbar and click status if showing and click enable in the next window, if when you right click on the icon in the taskbar and the option to 'connect' is displayed, click this instead. If non of the above work, you may have a faulty cable or network card.
Jul 31, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Linksys Wireless-G Broadband Router Logo
280 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
