Question about MSI K8N Neo4-F Motherboard
S/PDIF Location on motherboard
Hello
I have this motherboard (MSI K8N Neo4-F (MS-7125) Motherboard which came in a Systemax Ascent computer from TigerDirect. I recently bought a new Video Card ( Galaxy GeForce 9600 GT) with has a HDMI connection. The directions says in order to get sound from the HMDI Port I would have to run the provided cable from the video card to the Motherboard.
The issue is I can't location the jumpers on the motherboard to hook up the cable. Is this something you can help me with?
  • 661 Answers
If you look at the manual
http://www.msi.com/index.php?func=downloadfile&dno=3989&type=manual
it states that there are SPdif ports, I cannot see any hookups on the mainboard for these, however if you look on page 26 of the manual you can see that there is a coaxial output SPdif and an optical SPdif out, you should be able to connect to those without any problems
hope this helps
Posted on Apr 15, 2009
User manual MSI K8N Neo4 ver 1
Hello you can download the manual from here:
http://www.msi.com/service/search/?kw=K8N%20Neo4&type=product
By selecting the right maniboard.
Seach also by the ms xxxx number on the mainboard to get the right manual.
When you find your mainboard click on download
and select manual and download the pdf file.
Unzip the file after download.
You need adobe reader to read the content.
Good luck
Dec 09, 2012 | MSI K8N Neo4-F Motherboard
Need a users manual for ms-7125
http://www.msi.com/service/download/manual-4370.html
Select US, or chinese if you'd like.
If this answer helped, please rate it appropriately.
May 04, 2011 | MSI K8N Neo4-F Motherboard
I need drivers fo pci for ms 7125 please send
Hello the download site is here:
http://www.msi.com/service/search/?kw=ms%20%207125&type=product
http://www.msi.com/product/mb/K8N-Neo4-F--PCB-1-0-.html#/?div=Driver&os=All
If the driver not fit select another MB.
First select your windows system.
The drivers you may download needs to be unziped
before you install.
Good luck
Jan 02, 2011 | MSI : 7125-040 (K8N NEO4-F) Socket...
BEST HARD DRIVE FOR THE K8N Neo4 Series MS-7125 (v3.X) ATX Mainbo
HI. If you are a gamer/producer type. I would go with the Western Digital Veloci Raptor. You will not be disappointed with that monster. Now; If you are a moderate user that dose not crave for power and speed, and want a power saver/green drive, I would go with a Western Digital WD10EARS Caviar Green Hard Drive - 1TB. The green drive will save power and run quite well.
Veloci Raptor
Jul 22, 2010 | MSI K8N Neo4-F Motherboard
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
My pc keeps shutting down. It's not a virus. I think it's either power supply or motherboard cmos battery. My MB is MS-7125. I want to replace battery. Where do I get it and what kind?
is it getting overheated?
have you cleaned the heatsinks and fans lately?
Heat id the major killer of computers....it could be you need to clean things up so it stays cooler.
Could be a bad power supply as well.
Nov 13, 2009 | MSI K8N Neo4-F Motherboard
About MSI K8N Neo4
http://www.fixya.com/support/p298028-msi_k8n_neo4_f_motherboard/manual-15408
Sep 14, 2009 | MSI K8N Neo4-F Motherboard
MS-7125 ver1 K8N Neo4 motherboard problem
Do you have the K8N-Neo4 motherboard? MS-7125 is the intern p/n for the K8N
If so, try this address, these are the most recent drivers for the motherboard.
http://global.msi.com.tw/index.php?func=searchresult&keywords=MS-7125&table=download
Hope this is the answer you're looking for
Nov 19, 2008 | MSI K8N Neo4-F Motherboard
Where can i get the drivers for this mobo, audio , netcard MSI K8N Neo4-F ms-7125 platinum
this is the normal non platinumK8n
http://global.msi.com.tw/index.php?func=proddesc&prod_no=249&maincat_no=1&cat2_no=171
this is the platinum edition
http://global.msi.com.tw/index.php?func=proddesc&prod_no=242&maincat_no=1
by the way...one of the greatest mainboard I ever saw and tested..
I have myself a K9A Platinum..
good luck man...and fixya:)
Feb 08, 2008 | MSI K8N Neo4-F Motherboard
MSI K8N Neo4-F Motherboard Logo
1,026 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
