Question about Whirlpool LER5636P Electric Dryer
Voltage difference I have a Whirlpool model LEB6300PW1 dryer and a LEB6300PW4 washer. I am currently residing in Kuwait, is it possible to use these machines here? The voltage is 220v 50hz. Is there a different electrical cord so that I may use the dryer? I have a 5,000watt step down transformer, is it possible to use the washer that is 120v? It is 10amps, type 111 Thanks
  • 360 Answers
The voltage difference can be overcome. The problem will be the difference in frequency 50hz vs 60hz. The motors would have to be replaced with motors designed to operate at 50hz. The electronics would most likely need to be replace as well.
Best bet would be to contact whirlpool international to see if the offer a conversion kit/package.
Posted on Feb 02, 2009
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool dryer model # WED9270XW1? If yes, what stacking kit do I need to use?
You can stack just about any dryer on any washer, so long that the controls of the washer are on the the top of the washer has no penetrations and no control.In general, dryers are independent from the washer and are light weight.
So the conclusion: so long that the dryer does not interfere with operating the washer - YOU ARE A OK :-)
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
Where is the moisture sensor leb6300pw1
I think you will find it on the back of the drum right lower side
look for a black piece 2 by 4" on the inside of the drum should have 2 shiny bars on it. Hope this helps.
Apr 29, 2014 | Whirlpool Dryers
Need to know the year model of a whirlpool washer & dryer that belonged to my mom? The dryer Model #LER6848AWO and the washer Model #LSR7233BWO?
Mar 2009 dryer model #LER6848AWO serial and the washer model is Aug 2010 ... Model Number: LSR7233BWO. Hope you find this useful.
Apr 19, 2011 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
I have a stackable washer/dryer whirlpool model #WET3300SQ1. Heating element in dryer is not heating. We have replaced the heating element and it is still not working.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Aug 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LER5636P Electric Dryer Logo
114 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
