Question about HP Pavilion dv2000t Notebook
How can i desable sata hard drive in laptop for installing win XP
I have HP Pavilion laptop and i want to convert win vista to win xp .but when i run xp setup i got error message no hard disk
    Problem Solver:
  • 15 Answers
In the BIOS you should change the following option
sata native mode should be disable.
Posted on Feb 02, 2009
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
HOW TO INSTALL XP IN VISTA OS OF LAPTOP HP PAVILIION
Hi there.
The only way you can install XP on a Vista machine is to install "virtual XP" onto Vista using Virtual PC 2007.
Here is a site that will take you through the procedure step-by-step and gives links to download Virtual PC and install it onto the machine.
Please be aware that some drivers may not work whilst using XP when you have it installed.
http://lifehacker.com/software/windows/geek-to-live--run-windows-xp-inside-vista-with-virtual-pc-238071.php
Have fun, good luck and thanks for using FixYa!!
Mar 23, 2009 | HP Pavilion DV6700T Notebook
I have a hp 6735s with win vista installed in it. i want to use win XP but it wont install in this computer system.what should i do?
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
Solution:
this specific model HP 6735 was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
pls dont forget to rate me fixya for this help if u like
pls let me know if i can help u more
Mar 12, 2009 | HP Compaq 6735s Notebook
How to install xp in hp dv 2918tx laptop
This is a Vista laptop with a SATA hard drive. Windows XP does not have the SATA drivers, you therefore must slipstream the drivers to a new installation disk
Mar 11, 2009 | HP Pavilion dv2000t Notebook
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Problem on loadind windows xp on hp pavilion dv2000 laptop
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Nov 29, 2008 | HP Pavilion dv2000t Notebook
Non detection of hard disk in dell laptop while installation of win xp sp2
I haven't heard of not being able to delete a partition before. You could go to the manufacturer of the hard drives website and find the software to do a low level format or you could download a linux distribution and use the installer to remove the ESIA partition.
I would need to know the model of hard drive and laptop if you need any further assistance.
Sep 08, 2008 | Computers & Internet
I cannot install win xp on my hp pavalion
Hello
the easiest way out is to change the bios settings so that the disk is running in native mode, search for that settings in bios then the windows XP installation should find your disks.
other way is to have a Disk drive and download the sata driver from the manufactory site.
third way is to make a new xp installation cd with the new driver.
but try the first one first. little more info about your computer should be helping me to help your more?
good luck
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
How to install XP on pre loaded Vista in HP Laptop
I bought a cheap Compaq laptop that came with Vista Home Premium. The speed was horrendous! Anyway, I received the same no hard drive found error. To solve the problem, I went into the system config (BIOS) by pressing F10 on startup, and turned off SATA hard drive support (its supposed to make the hard drive run faster), I rebooted, inserted my Win XP Pro disc and viola, it detected the hard drive. I would say that the laptop runs a good 40% faster than before. Vista is a big no no when it comes to low end laptops built for word processing and internet browsing.
Aug 19, 2007 | Microsoft Windows XP Professional With...
HP Pavilion dv2000t Notebook Logo
191 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
