Question about D-Link DSL 604+ (DSL-604+) Wireless Router
Computer says connected to internet,, wont display page
I have a LAN network,, one internet connection works fine. I pluged another network cable into another computer to work for a second computer. I cant get onto the internet with the second comuter,, they both run from shaw modem through my dsl-604+,,,,help is this not a possabillity??
  • hardyboy829 Feb 03, 2009
    Thank you so much for the response!! I made contact with the tech team from Dlink,, and we found that the router i have is from telus. I have to contact telus to get a pass word so it can be reset, then it should be able to be set up for me,, again thank you for the info, it is exactly what D link tech team told me to do....
  • Anonymous Mar 16, 2014
    willnot connect to internet
  • 36 Answers
Usually routers are setup using DHCP... on your second computer. try going to
start, control panel,  networkconnection,  "your LAN connection",\ properties Internet Protocol (TCP/IP) (should be checked)
Obtained Ip address automatically should be selected
Obttained Dns server automatically should be selected.
then click OK, OK to save settings...
if your router is not setup as a DHCP,it would require you to setup your ip address manually... let me know if this dont work, so  i can help u setup manually...
if it helps, try comparing the settings of your pc1 and pc2 (the network connection settings)
Posted on Feb 03, 2009
Bought and installed a usb wireless lan for my desk top, it brings up all the wifi in my area, i can connect to my wireless router i am using now with my laptop but wont bring up web pages. shows i am...
To test your Internet connection use a LAN cable, connect to your laptop to your router and if you can get an Internet connection then most likely your USB wireless adapter is not configured correctly for connecting to your wireless router.
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 11, 2012 | Computers & Internet
Hi, Im using Linksys SR224 24 ports as my main switch. I got a poor internet connection, this problem occurs few weeks ago. I tried to connect my modem through a LAN cable directly to my server and...
Try a brand-new cable between the modem and the "uplink" port on the router.
Try a brand-new cable from one of the "LAN" ports to your computer, and test to see that you get a good connection.
Jan 04, 2011 | Linksys SR224 (srw224) 2x1000 Mbps...
Emachine won't connect to the internet. Ethernet cable, router and modem all work just fine. problem is with computer. Check network adapters in device manager and no problem noted there. Why won't it...
first try to check if your wireless can actually detect a network, if it can try to remove ALLthe network that you have on your wireless network and try to add your network again, if still doest work try to uninstall and re install your wireless driver, if it still doesnt work try to restart your router, if still doesnt work try to do system restore to the point where your wireless was workin fine, lastly if still doesnt work try to contact your ISP for some configuration.
Jun 02, 2010 | E-Machines eMachines Desktop PC
My router works fine with a cable pluged into the computer, but when i unplug the cable to access the wireless internet it will not pick up any wireless connection. sometimes it will have the connection...
You should reset your router by sticking a pin in the pin hole on the back.
Once reset, reconnect a LAN cable and then reconfigure the wireless network.
If you keep having trouble connecting, try changing the channel your wireless network is being broadcast on.
Mar 26, 2010 | NetGear WGR614 Wireless Router
Dell TrueMobile 2300 Router wont connect to My cable modem
You are most likely making a mistake in the setup instructions.
Jun 20, 2017 | Computers & Internet
Router cannot connect to the internet
I assume you are following my instructions.
Did you connect the LAN cable from the DSL or cable modem to the WAN or Internet port on the wireless router?
To test if the modem is working properly, connect the LAN cable from the modem to the LAN network card on a computer and see if you can access the Internet.
If if doesn't connect to the Internet, contact your ISP and they can check the connection to your modem to determine if it is working properly.
Dec 03, 2009 | Linksys WRH54G Wireless Router
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Internet Applications wont connect - Vista
I am running Windows 7 (the new vista) so I hope I can help. Go to the "Start" button and select "Control Panel". Click on "Network and Internet" and then "Network and Sharing Center". You shouls see something like: Computer =====Network ====== Internet. If there is an "X" on one of the connections, that may help you decide which option further down to try. You can keep me posted if this helps to this point.
May 28, 2009 | Computers & Internet
Lan problem
You LAN is not connecting to your Internet Service Provider, hence the LAN has a red X and therefore cannot open a WEB page.
Check your LAN cable, make aure it is connected to both the LAN port on the modem and the LAN port on the computer.
The red X on the LAN should disappear when the network connection is re-established.
Also power off your modem for 1/2 min, and power it on again and restart your computer.
Let me know if you have further problems and any error messages.
May 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Rangemax-internet only works when comp directly connected via LAN
it sounds like you have the wireless connection to the WAN disabled. Go through the wireless settings on the router and check to make sure it's not being blocked from the WAN/Internet connection.
Nov 11, 2008 | NetGear RangeMax WPN824 Wireless Router...
D-Link DSL 604+ (DSL-604+) Wireless Router Logo
178 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
