Question about Pentax K1000 35mm SLR Camera
Black bar on rt. side of photos.
I have a Pentax K1000 that I quit using 15 years ago because there was a black "bar" on the right side of my photos. It sounds like a timing issue(?), is this fixable?
    Scholar:
  • 185 Answers
Elockepens
is this black bar on all the time or only when using flash? if only when using flash then your shutter speed is to high. for flash on the K1000 the shutter speed must be 1/60th sec. or slower.
if the black bar is there all the time then the shutter must be adjusted, cleaned and lubed.take or send your K1000 to a camera repair shop for an estimate first as there are no new part available,
Posted on Feb 02, 2009
How do i find out the year my pentax k1000 was made?
Hi Joy,
The folks over at Pentax Forums had the same questions. They created a database with information that they could obtain from their member's K1000 cameras. This is not an official list - but just what some folks cobbeled together on their own. You can download it from their page, here.
From what I can tell, there were people that purchased K1000 with lower and higher serial mumbers than yours in 1986 (s/n 7785273) and 1987 (s/n 7817712). That indicates yours was was likely manufactured about the same time.
I hope this helps!
Feb 08, 2013 | Pentax K1000 35mm SLR Camera
I have a Pentax k1000, and was given a few vivitar and olypus lenses. They do not fit the camera. What can I do?????
Vivitar makes lenses with a variety of mounts. Lenses with the Pentax K-mount can be used on the K1000, lenses with other mounts can not.
Olympus lenses will not mount onto a Pentax camera.
You can sell the lenses, give them to someone with the appropriate camera(s), or use them as paperweights.
Nov 21, 2012 | Pentax K1000 35mm SLR Camera
How do I find out the year my Pentax k1000 was made using the serial number? The number is 8410441.
www.pentaxforums.com/forums/pentax-slr-lense-discussion/117545-lense-serial-number-database.html,this is one of the most comprehensive pentax serial number databases around,just click the link i have provided ,once you get there find the k1000 section and find your serial number and that should tell you what year it was made,good luck,if this helps you out please give me 4 thumbs up,it helps my rating,thanks
Feb 10, 2011 | Pentax K1000 35mm SLR Camera
On my pentax asaih k1000 when you look through the lense its black- i dont know if the mirror might have fell out or what...
If you look through the view finder and it is black, the mirror is hanged up and the shutter is jammed. The mirror is still there.
May 31, 2010 | Pentax K1000 35mm SLR Camera
On my pentax k1000 the black fuzz looking stuff
That's the mirror bumper, it softens the blow and cuts the noise as the mirror flips up.
Carefully remove it and then replace it with a new one. You can get it as part of a foam light seal repair kit for your camera; this also ensures that the sticky black goo which used to be foam and which prevents light from getting past the edges of the camera back gets replaced. Light seal kits are very cheap, and if you buy a pre-cut version then it makes a fiddly job a bit easier and potentially less messy. They're widely available on sites like ebay, just search for "k1000 light seals" and check that the kit includes a mirror bumper/buffer.
If you don't get it repaired the fuzz will get everywhere and can also get onto the film surface causing white spots on your photos or black spots on negatives/slides. The debris can also get into your lenses so remove it asap. Gooey foam light seals are even worse as it's both corrosive and abrasive (due to the grit it attracts) and gradually migrates to gum up the works. It can also result in light fogging on your photos (usually seen as red streaks from the top or bottom of the picture). Modern foam seals do not decompose like the old ones did.
I hope that I've helped you, please take a moment to rate my answer.
Mar 02, 2010 | Pentax K1000 35mm SLR Camera
My Pentax K1000 ser. # is 6636745. Can you tell me what year and where it was made?
Nothing official mind you- but some folks on the pentaxforums.com put in all their K1000 info and one of the admins complied said info and came up with their own chart.
http://www.pentaxforums.com/forums/pentax-film-slr-discussion/51190-k1000-serial-number-database.html
if their information is true then your camera would have been manufactured between 1977?-1982
run From To years manufactured
1 7 5xx xxx 7 7xx xxx 1976 - 1978?
2 6 0xx xxx 6 9xx xxx 1977? - 1982
3 7 0xx xxx 7 4xx xxx 1982 - 1983
4 7 8xx xxx 8 4xx xxx 1984 - 1989?
5 4 xxx xxx 5 6xx xxx 1989? - 1997
Oct 08, 2009 | Pentax K1000 35mm SLR Camera
Missing battery cap
I lost the battery cap of my K1000 on vacation...I replaced the battery and taped it snugly in place with a bandaid. It hasn't budged in a year! Just find a good strong tape and tape over the battery.
Aug 26, 2009 | Pentax K1000 35mm SLR Camera
My shutter is sticking; half of the picture is black
This is not a user repairable problem.
You need to take it for a professional repair. The good thing is that this is an all mechanical SLR and was designed so that repairs are usually straightforward. Spares are no longer available, but so many of these cameras were sold and are still in use today that many repairers have a few scrap examples which they can cannibalise when needed.
Given that you can buy a perfectly good used K1000 at online auction sites for between £30-£40 it may not seem like an economical repair, but newly serviced ones with a guarantee sell for over £100 so it's definitely worth it for such a superb classic SLR.
Jul 09, 2009 | Pentax K1000 35mm SLR Camera
What kind of battery does the pentax k1000 35mm SLR camera take?
Yes the K100 uses LR44 or G13. I would recommend the G13
Nov 12, 2008 | Pentax K1000 35mm SLR Camera
Can't get my lense off!
You can use any mm lens you want as long as it was made to fit the K1000.
Is the lens a Pentax lens ?
Push the lens release button down and turn lens Clock-wise then while holding release button down quickly turn lens counter clock-wise, it should come right off.
If it did not then it must be disassembled to remove the lens.
Oct 31, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
140 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
