Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
How do i turn the light on my lcd display? - Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
    An expert whose answer gotĀ voted for 100 times.
  • 201 Answers
If your time display is not shown on the LCD, press FN and F9 at the same time until the display appear.
YBC (/\)
Posted on Oct 23, 2009
How to Test a Remote Control With a Digital Camera.
Turn on your camera to view the display on the LCD screen. Point the remote control to the camera's lens. Press the remote controls buttons and observe on the camera's LCD screen or viewfinder that the remote control emits infrared lights from the transmitter IFR light. If you don't see any lights on the camera's LCD display from the remote control, then the remote control is bad.
on Nov 03, 2010 | Televison & Video
Lenovo 3000 n100 lcd display works but only less than a minute before display goes black. Connect an external monitor and it works fine.
possible problem is your led light on your LCD or its Flex. you might need to have it replaced. Try to check your LCD when it turns black under the light if you can see a dark image of your desktop. If you can see your desktop then the backlight has a problem. If there is no display, your LCD needs to be replaced.
Aug 13, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
W2606c lcd tv
Nothing appears on my LCD TV display
1 Ensure the LCD TV display is turned on.
2 Verify that all the cables are properly connected to the LCD TV
display, including the power cable.
3 Check to see if there is a blue or amber light on the lower,
right-hand corner of the LCD TV display. A blue light indicates
the LCD TV display is on. An amber light means the LCD TV
display is in power save mode.
4 Ensure the proper source is selected in the Input Select menu.
See "Input Select Menu" on page 24 for more information.
5 Reconnect any devices that are currently connected to the LCD
TV display. If you are using multiple devices, connect and test
one device at a time.
6 Connect another device that you know is working properly.
7 Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Problem Possible Solution No sound
1 Ensure mute is not turned on. Pressing the Mute button on
the remote control turns the mute function on and off.
2 If only certain LCD TV channels do not have sound, then you
need to correct the Input Select menu in the TV Menu (see
"Input Select Menu" on page 24).
3 Verify that the audio cables are firmly connected to both the
audio input connectors on your LCD TV display and audio
output connectors on your devices. Ensure that the cable colors
match the connectors colors.
4 Also, ensure that the audio cables are connected to the same
row as the video cables. See "About Your LCD TV Display" on
page 5 for the location of the connectors.
5 Reconnect the device using the same type of connector. For
example, if you are using the composite connector on the
bottom, try connecting the device to the composite connector
on the side of the LCD TV display. See "About Your LCD TV
Display" on page 5 for the location of the connectors.
After you connect the device, change the input source in the TV
Menu. See "Input Select Menu" on page 24 for more
6 Connect the device using a different connector. For example,
if you are experiencing the problem using a composite
connector, try using the component connector.
NOTE: To connect to a different connector, you need the
appropriate cables for that connector. See your device
documentation for a list of supported connections.
7 Test the device on a different TV.
Jan 05, 2009 | Dell Televison & Video
No display on sansa e200
This is a common symptom of defected LCD,you must replaced the LCD so its works better again.
Hope it may help you;
Oct 10, 2008 | SanDisk Sansa e250 MP3 Player
PowerBook g4 15" Screen Won't Display Anything!
your lcd probably just went out or the connecting cable just came loose(its in behind the lcd under the apple logo that lights up when you turn it on) if you open and close it frequently it will cause this
May 26, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Nokia1600 repairing
hi there sir must go to your nearest service center to replace your LCD it must be damage already. the light of that phone was built-in to the LCD display. and that is why also your keypad doesn't have light cuz' it is series to the display light.
Mar 30, 2008 | Nokia 1600 Cellular Phone
LCD's won't power up
The LCD not displaying a picture may just have a back-light issue. You can verify this by turning on the display, taking a flashlight and pointing it at the LCD then looking at the area that is illuminated on an angle and up close (1" - 2"). If the picture is visible then it is a back-light. You either need an LCD back-light inverter or the back-light itself.
Nov 08, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
152 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
