Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer Feeder not working well. Paper always gets stuck.
How can I fix this problem? Unless I hold the paper down or have enough paper in the paper tray, the paper never feeds properly and eats up the paper when printing. I have to hold the paper down and make sure the paper goes in flat and smoothly before it prints correctly. Also, if I put in the photo paper, it doesn't print well and most of the time eats up the 8.5 x 11 photo paper.
Does anyone else have this problem?
  • mweik Feb 03, 2009
    Same problem here, paper jams if paper tray not full, now jamming inside.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 684 Answers
Recurring paper jams can be caused by broken parts, using too much paper in the in-tray, or parts (usually the rear door) not on all the way. This video explains how to fix a paper or carriage jam, but explains along the way the things to watch for. If you go through the steps in this video and you still get paper jammed, you may have a broken printer that needs to be replaced or repaired.
Posted on Jun 18, 2009
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Loaded paper not going through
    Annie, did you try to feed it one paper at a time? in many printers the feeder doesn't do a good job separating one paper from the rest.
    another thing you can do is to turn off the printer and back on. this might get it out of the stuck status it is in.
    did you check there isn't any paper stuck in the feeder?
    Mar 10, 2010 | Lexmark X5470 All-In-One InkJet Printer
    Paper feeder is off so paper gets stuck
    Hello , sometimes what happens is that there could be objects blocking the path of the paper on one side. Maybe a paper clip or a pen, I have seen this many many times. Just turn off the printer and remove the paper from the feeder. Unplug the printer from the power cord. Then flip the printer upside down and shake it a little most of the times you will find something stuck in there and it will fell down. If you do not find anything maybe then there is something wrong with the feeder roller. Also try the following link http://bit.ly/9nrlMW
    Feb 03, 2010 | Lexmark X5150 All-In-One InkJet Printer
    Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
    Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
    Keep printer unplugged for about 2 minutes and replug and try a test print.
    Also make sure that you have waited long enough for the printer to heat up before giving a print job.
    Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
    Hope that helps!
    Thanks
    Newton
    Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
    Paper jam
    Turn the printer off and open the access cover.
    Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
    Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
    Watch the paper as it feeds through and try to determine where the jam is occurring.
    Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
    If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
    Turn the printer off.
    Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
    Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
    If the paper is lodged too far into the printer and can't be removed:
    Press the power button to turn the printer off.
    Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    Close the front cover.
    Press the power button to turn the printer back on.
    Resend your document to print.
    Ensure that:
    The paper is a recommended paper for inkjet printers.
    You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    The printer is on a flat, level surface.
    The left paper guide is against the side of the paper.
    You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    The left paper guide does not cause the paper to bend in the sheet feeder.
    Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    Envelopes or the appropriate specialty papers are selected in the printer driver.
    You are using a paper or envelope size supported by your printer.
    Mar 24, 2008 | Office Equipment & Supplies
    Lexmark e320 thumping on feed
    The printer may report load paper when there is enough paper present in the feeder, however this could be due to number of reasons such as if there is something which is blocking the paper to flow through the feeder anything for example, some foreign martial like a pen or a pencil, please find few steps below to fix this issue.
    1. Confirm that no foreign materials are inside the machine.
    2. Confirm that usable paper is set.
    3. Confirm that the paper is set properly.
    4. Confirm that recommended paper is used, and the number of sheets are not exciding the required number limit.
    5. Adjust the paper feeder guide to the sheet size.
    6. Disconnect the printer power cord as well as the printer cable form the printer.
    7. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
    Open the printer cover and remove the cartridge and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
    8. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
    9. Try to rotate the wheel inside the feeder if you can reach it, to ensue that it is free enough to pull the paper.
    10. Try printing with having only one sheet in the feeder and check if it does work.
    Should you require any further assistance regarding the printer or even any other compute related issue please feel free to contact me I will be more than glad to assist you.
    Regards
    Malik Khan
    Jan 31, 2008 | Lexmark E320 Laser Printer
    Paper loading
    The issue you have posted regarding your printer which is un able to load the paper could be due to number of reasons like if there is any foreign material for example pen, pencil or any other obstacle which is blocking the paper to feed through the printer feeder then the printer will not be able to load the paper. However I would appreciate if you try the steps below in order to fix the issue.
    4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit.
    5. Disconnect the printer power cord as well as the printer cable form the printer.
    6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
    Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so remove it carefully.
    7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
    8. Check and set the paper guide in the feeder to the paper size.
    9. Try loading a single sheet and check if it is printing.
    10. Try different type of paper.
    11. try to rotate the roller inside the feeder which pulls the paper manually if possible to ensure that it is not jammed
    Should you require any further assistance regarding the printer or even for any other computer related issue please feel free to contact me I will be more than glad to assist you.
    Regards
    Malik Khan
    Jan 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    Brother MFC paper jams on one side
    Honestly? Unplug the machine...REMOVE THE DRUM UNIT!!!!! and other parts not locked down. Turn it upside down and shake it lightly to moderately. You can also try holding the lever forward while you do this. This has worked for so many machines you would be surprised. You might be even more surprised what comes out. I have seen pens, pieces of ceiling tiles, wire clippings, Matchbox cars, and grape jelly (I didn't ask).
    Dec 16, 2007 | Brother MFC 6800 All-In-One Laser Printer
    Paper problems
    I had same problem. first turn of the printer and unplug electrical supply. turn the printer upside down and make sure there is nothing stuck in paper feeder. the next step, take a paper sort of a greetings card and try to run it through the feeder gently. if you cant get it through then don't force it. but this will clear up any object stuck in to paper feeder. now plug in yor power cord and try a test page from your printers properties. hope this will work for you. good luck...........
    Aug 16, 2006 | Dell 810 All-In-One InkJet Printer
    HP Photosmart C6180 All-In-One InkJet Printer Logo
    421 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
