Question about E-Machines eMachines Desktop PC
My Emachines Desktop W5243 works sometimes and others just beeps
My desktop will work ok for a week or so and then out of nowhere when I try to turn it on it will beep non-stop and nothing comes up on the screen. When it does this the fan comes on but then beep..beep..beep..beep. If I leave it unplugged for a week or two and then plug it back up one day it will resume working as though nothing ever happened. It is very aggrivating since I don't know when it is going to happen. I had a friend look at it and he checked the power supply and said he doesn't think that is what it is. He says it is working fine for him but I know that when I get it back it will start doing the same thing again. I have read some of the responses to similar problems on here but would really appreciate any advice you have to offer.
I am running Windows Vista Home Premium, and the specs on the pc are : emachine w5243
serial number GC575C 400 06852
athlon 64 processor 3800+ 2.4 ghz,512 kb L2 cache,
2000mhz system bus
1gb memory DDR2 dual channel memory
250 gb hard drive
super dvd + rw optical drive
nvidia geforce 6100 integrated graphics
10/100 mbps ethernet lan
  • kennedy_hutc Feb 05, 2009
    I will try your suggestion thanks so much for the advice.
  • 2,404 Answers
You might be having a minor dust particle situation going on. Take the memory out of the system. Get a can of air and blow out the slots on the motherboard where the memory would normally go. Then take the can of air and blow the connectors on both sides of the memory. After this then put the memory back into the slot firmly. Don't worry cause the memory can only go in one way in the slots. It should snap into place. After this then turn the computer on and it should boot up fine. If you keep having intermittent problem after this then replace the memory.
Posted on Feb 02, 2009
Open your system , remove the RAM and erase the golden color part with a pencil eraser. Make sure the part looks new and shiny before placing it back and turning on. Wired but true solution worked for many
Jan 28, 2013 | eMachines W5243 Refurbished AMD Desktop...
When I turn it on it doesn't boot, it makes a beep every 10 seconds or so, and the moniter says no signal. I dusted out the inside and it worked fine for a few weeks but now its not working again. I tried...
It normally means that it hasnt detected ram or some other similar piece of hardware, try making sure all your ram sticks, cpuand heatsink and hdd are connected properly
Dec 12, 2010 | E-Machines eMachines Desktop PC
An emachine w5243 when i turn it on it post and then turns off
Check all the connections and try again. If that does not work you will need to open the computer up and check the connections in there. When you have the computer open look at the motherboard for some small round like tubes (called Capasitors) if any of them are bulging or have crud on the top of them they have gone bad and this could be causing the issue with your computer.
Jul 01, 2010 | E-Machines eMachines Desktop PC
How do i defrag a emachines pc model W5243
if you have WINDOWS XP , go to START ,then go to ALL PROGRAMS , then go to accessories , then click SYSTEM TOOLS , then go to DISK DEFRAGMENTER , HOPE THIS HELPS AJ
Jul 28, 2009 | eMachines W5243 Refurbished AMD Desktop...
Installation guide for video card on a emachines w5243
Providing this card is compatible with your system you just open the side, take out the screw or clip remove the old card and install the new one, upon boot up insert the CD that came with the card. Or let Found new hardware wizard take over.Also it's handy to have another computer nearby to serial connect to so that you may view that screen.
Jun 22, 2009 | eMachines W5243 Refurbished AMD Desktop...
My E-Machines desktop just stopped working. A few weeks ago, my user was corrupted so I had to do a system restore to get to my data on hard drive. Did that and backed up to external drive and it worked...
that beep means POST.. your computer hardware is fine .. please just re install the operating systemm... before that you might want to back up the hard drive data using bartpe or some tools similar to that.. if you dont have that expertise. just re install the operating system .. you should get back to work...
remember beep meaning POST meaning your hardware is fine.. the operating system is just corrupted / broekn
May 13, 2009 | E-Machines eMachines Desktop PC
How to connect my eMachines W5243 Desktop PC to my basic sharp tv
This requires an svideo or composite output. You may have to buy a special adapter or card.
Mar 08, 2008 | Computers & Internet
Emachines wont boot
Bad capacitor(s) on the motherboard can cause this problem, corrupted BIOS maybe... try flashing BIOS.
Probably the CPU if your not getting any error code beeps on startup.. NO Processor for the BIOS instructions thus no Beeps !
Nov 27, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
217 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
