Question about Frigidaire FRS26R4A Side by Side Refrigerator
Compressor bad I have a 5 1/2 year old refrigerator and the compressor has gone bad. should I replace or buy new? About 1 1/2 months ago it stopped cooling and I put a hard start (3 in 1) on it, so I guess the compressor was going bad then. Now I have tested with an ohm meter and the compressor has grounded. Could putting the 3 in 1 on it messed up anything else? Any advice? Thanks!!!!!
    Director Badge:
    Uploaded 100 video answers.
  • Frigidaire Master
  • 488 Answers
Its not DIY stuff to replace compressor. here is my video how i do it. replacing little compressor. pretty similar to any residential refrigerators.
Posted on Nov 26, 2015
  • Frigidaire Master
  • 4,654 Answers
Dawnrock, Go buy you a new refrigerator. You looking at $350.00+ to get it done right. I Know! I do them and a refrigerator is no simple project to fix.....Good Luck, Sea Breeze
Posted on Feb 02, 2009
How to replace defrost timer
a bad defrost timer can be checked with a multi meter
Sep 08, 2014 | Whirlpool Refrigerators
Hello, I have a Kitchenaid Superba KSRB25FHSS02 side by side refrigerator. It was made in 1999 and came with the house. Two years ago, the compressor went on it and we had it replaced. A couple days ago,...
It's really up to you, to decide whether you want your refrigerator to be fix or replaced and buy a new one. You need to calculate the cost between repair cost and the price of a new refrigerator. Which one is suited your budget plus the convenient of the trouble free unit for many years to come.
Since your refrigerator is about 12 years old already and it's undergo several repair, including the most expensive compressor replacement. I think it's economical to spend for a brand new unit.
New unit have service warranty of about one year, it will take many years before it undergo service repair if you use and treat it with proper care.
Good luck on your decision.
Jul 03, 2011 | KitchenAid Superba KSRG25FK Side by Side...
THE REFRIGERTOR JUST STOPPED WORKING IT IS 5 YEARS OLD AND NOT OVER USED
The overload/start relay may have gone bad.
Other possible causes:
* Bad thermostat. Check thermostat
* Defrost timer. Not definite but possibly bad. Last resort.
*Concentrate on getting the compressor to run first.
Once the compressor runs again, observe the refrigerator for a while to confirm cooling.
If there is no cooling after at least forty five minutes, your refrigerant may leaked out.
Do not despair, get the compressor running first. The worst case scenario would be a burnt compressor, and that has not been established yet.
Dec 22, 2010 | Magic Chef MCBR440 Compact Refrigerator
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Compressor works but compressor fan does not
It is possible the capacitor has gone bad, cause, possibly a power surge. Suggest replacing capacitor first and see if problem happens again then I would change fan motor and capacitor. Good luck on your repairs
Dave
Dec 07, 2009 | Heating & Cooling
26 Cu Ft Side By Side Maytag Refrigerator: Relay Failures
you have more than likely got a bad compressor it is pulling to many amps you need to replace the compressor
Jul 12, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Amana ARB8057CSR
I have the same unit, same age, same problem. I'm pretty sure it's the compressor acting up. Figures, just out of warranty. Probably will end up buying a new fridge (No Amana, that's for sure!)
Jun 15, 2009 | Amana ARB8057CSR Bottom Freezer...
I have a frigidaire refrigerator model #FRS6R5ESBC that stopped cooling. I replaced start relay on compressor and discovered that defrost control was burnt out replaced it also. now in less than 3 days...
Had one a couple years ago did the same thing. Found the compressor was going bad and was pulling too many amps thru the control. Ended up buying a new frig.
Apr 08, 2009 | Frigidaire FRS3R5EMB Side by Side...
Compressor bad
I would think that compressor would cost a lot of money.So if I were you I would buy a new refrigerator .
Feb 02, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
128 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
