Question about Refrigerators
You Guys/We making any money?
No Problem here just trying to feel my way around. Kinda struggling here with the economy. Need to find out who to hang out with in the blogs and get some advice from the crew. Having a little trouble getting to those premium Q&A's.............Sea Breeze
  • John Tripp
    John Tripp Feb 06, 2009
    You answered my question perfectly, Thanks
  • 679 Answers
Nothing all day, been like this for a few days now if you look in the experts lounge
Posted on Feb 06, 2009
Recently my c230 started running really rough. Kinda choppy. I was giving a friend a ride home, it was around 102° and my friend weighs over 300 lbs. when we were going over the overpass I could feel the...
before you listen to friends and guessing and wasting money, always make it a point to have the fault codes read first. The problem may be where you suggest but it could also be faulty injector/s, canister problems not venting the tank properly, sensors in the exhaust or any number of other items.
Feb 25, 2015 | Cars & Trucks
Hey my 2006 Suzuki swift has been playing up for around 6 months now and I think it's time to fix it, things I've come across is... Constant revving up and down, check engine light either on all...
all the faults of the car dont need to be fixed all at once
you can stretch it out
idle control valve can be cleaned
the maf can be cleaned
air filter can be cleaned
replace spark plugs
disconnect battery terminals count to 5 then reconnect
see if the engine check light stays off
if the light comes back on
engine check light on means fault codes are stored in the ECU to be read
shop around for the cheapest place that can do a 10000 km service
and nothing more
Apr 16, 2017 | Cars & Trucks
The problem- i was told the car is in safety mod, anytime i get around 4,000 rpms it feels like im topping the car out it kinda jumps, it feels like it struggling my check engine light went on for a few...
it can be a 02 sensor. it can be spark plugs or even the spark plug cables.
it also can be oil level. check oil level in the transmission oil, if you have to much, it can also creates this problem.
you can also spray some sea foam deep creek thru the vaccumm lines or the air intake to clean the bodies.
Apr 28, 2010 | 2003 Nissan 350Z
Why I have a lot of struggles all my life?
gear up dear friend !!,,,
oppurtunities are more , there is lots of ways to make money.
i think you can adopt a kid .
Mar 19, 2010 | Orange PCMICROSTORE Brand Nokia 5300...
Spacemaker XL1400 will not heat. Imagine that everything else wor
The magnetron is bad and possibly the diode, should cost betweet $150-180 to repair. if the tech doesn't have the parts with him the first trip be suspicious, that is the most common repair on your microwave
Feb 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Pc hang when there is disk inserted on my dvd ram..
Your DVD drive needs serviceing, you can use a lens cleaning CD,
When you insert a Disk, it keeps on trying to read it, so the PC hangs meanwhile
Jan 16, 2010 | Computers & Internet
What kinda performance problems make my car act the way it does.
COULD BE JUST TUNEUP,CHANGE THE ELECTRIC COIL PLUGS CAP&ROTOR,WIRES CHANGE THE FUEL FILTER
Oct 29, 2009 | 1994 Ford Escort
P0202 AND P0302 ERROR CODES. CHANGED SPARK PLUGS ALREADY, BUT THAT DIDN'T FIX THE PROBLEM. JEEP FEELS LIKE IT'S PULSATING WHEN IT'S STOPPED BUT RUNNING. FEELS LIKE IT IS STRUGGLING FOR POWER WHEN...
P0202 is cylinder 2 injector circuit malfunction. And P0302 is cylinder 2 misfire.
The # 2 fuel injector is the problem not the spark plug.
Check to make sure the electrical connector is still plugged in to the injector. The injector is right below the the #2 plug. If you have an electrical tester check the Ohms between the two contacts on the injector. It should be around 12.
Another way to check your injector before you spend the money is to switch two of them. Just make sure that you get yourself a manual. It will guide you through the injector removal better then Something like this.
If it's any consolation I have a similar problem P0202. Unfortunately I have no compression in # 2 cylinder which means a possible blow head gasket. I'll be happy to trade you.
Good luck
Sep 03, 2009 | 2001 Jeep Cherokee
Got a yellow vacuum hose hanging from the climate control. Air conditioner only blows through the defroster. I think this hose controls the door to route the air to the vents.
There are air pods on the heating and cooling system that opens different vents. Look under either the drivers or passenger side dash and feel around. It will be kinda hard to find just take your time and a flash light so you can see what your looking for.
May 12, 2009 | 1999 Lincoln Continental
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
