Question about Dual Electronics CECT P168 Cellular Phone
GETTING PICS OFF MY I9 PHONE.
NOT SURE HOW TO GET PICS OFF MY I9. I'VE TRYED CONNECTING IT TO MY PC BUT NOTHING HAPPENS. CAN U HELP ME
SAVE THE PICS TO YOUR MICRO SD CARD AND PUT THE CARD INTO THE SLOT ON YOUR COMPUTER.
Posted on Feb 04, 2009
Try this. make sure your phone is turned off then plug the usb cable into both the phone and the computer. Next if a promtp screen doesnt come up on the computer asking which application you want to use go to your start menu on your computer. Then go to your My Computer, look for Removable disk K, click on that and it should show the folders in your phone, then right click or left click to do what you want to do with the contents of the folder.
Posted on Feb 02, 2009
How can i send pics from my i9 to my computer
Hi archie7216, connect your phone to computer via your usb cable on the phone choose mass storage. Go to my computer and you will see extra removable storage icons open each one they have a list of folders check the photo folders and you should find your pictures. If you can't get your pics to the pc download PC-Sync Manager it should make it easier.
Dione
Feb 22, 2010 | Motorola Mobility Boost Mobile...
How to download music to my i9 mobile phone?
Hi melissaandsa. Connect the i9 to the PC.
The i9 will ask how it will be used by the PC.
Use "Mass Storage"
You will now see 2 new drives appear on you PC.
1 will be the phones memory the other will be the memory card.
Simply copy and paste you mp3's to the "My Music" folder.
Now you will see all the folders in the "My Music" or "MP3" folder.
Your music should be in your audio player.
It may ask you to reload or something similar accept and it should relist the music.
If not try changing the "List auto gen." option if you get no list ...
You get to the "List auto gen." option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
    1.) Tap the little wrench icon to the far right on the black option panel,
     then scroll down to the List auto gen. option!
    2.) Tap the List option at the bottom of the screen, tap the Options button
     at the bottom of the screen, tap the Settings button, scroll down to List auto gen.
Now also make sure that in the "options" you are pointing at the SDcard.
One of these should help.
Dione
Feb 07, 2010 | Dual Electronics CECT P168 Cellular Phone
CECT i9 stopped communicating with PC
Is it the same computer you've always used? It could be the OS not recognizing your phone or a bad USB port, if it is the same computer, most likely it's your phone. Try doing a firmware update and see if that helps. You'll have to use a microSD adapter to save it to your card since the cable doesn't work.
Aug 06, 2009 | Dual Electronics CECT P168 Cellular Phone
My computer does not recognise my CECT i9 phone
Switch the phone on, then connect. You should have 3 options; Mass Storage, Webcam and PictBridge. Select Mass Storage. Depending on your system on your PC will connect immediately or maybe (older model) ask for driver. Driver for mass storage is 'generic' so will install automaticaly. After that go to 'my computer' and there will be 2 (!!!) new 'drives', the first one the external card on your phone, the second one the internal drive of your phone.
May 30, 2009 | Dual Electronics CECT P168 Cellular Phone
Can't get into my i9 phone
send it back, these phones are COMPLETELY worthless wihout the touch screen. the person i bought my phone was always happy to helpme out, hopefully yours is too.
Apr 21, 2009 | Dual Electronics CECT P168 Cellular Phone
Is the Cect I9/I68 Mac compatible?
Yes, you can connect the phone as a mass storage device via USB or bluetooth. Maybe there is even a PC suite software. Ask at http://chinamanuals.com - they a least have one for Windows systems.
Mar 09, 2009 | Dual Electronics CECT P168 Cellular Phone
I9 phone does not recognize the USB connection with the computer
Plug in the phone while it is turned off. It should update the drivers. If that doesnt work turn off the phone and the computer. Plug the phone in to the computer and turn the computer back on.
Feb 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Please tell me exactly how to put java apps and movies on the i9
Ok, Its pretty simple to add java apps/games and movies to your i9. just
1) connect your phone to your pc via the usb.
2) go into your i9 phones memory card (the first of the two letters) i.e I = phone memory , H = memory card.. so go into the H drive.
3) Create a folder call 'JAVA' and simply drag your downloaded apps/games from your pc into your 'JAVA' folder on your memory card!
4) When you disconnect you phone, go to java in your phone menu then you can install the apps/games.
(step 3 only need to create 'java' folder once)
For movies
1) repeat step 1 and 2 above ^^
2) drag the movies from your pc into 'Movies' folder on memory card
3) disconnect phone from pc and you can now watch on your phone!
Note: i9 phone supports 3GP, AVI format only.
Jan 24, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect i9 wont charge battery is fine
the issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
Dec 10, 2008 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
74 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
