Question about HP PSC 1610 All-In-One InkJet Printer
Cannot boot up Windows XP except in Safe Mode
I do not know what corrupted the boot process on XP, but suddenly I can't boot up except in Safe Mode. I have tried restoring to an earlier time and booting to last known configuration with no luck either way. Any solution?
  • 4,655 Answers
Sounds like adaware32 worm if and when you get it up and on-line go to microsoft and post your issue. A lot of XP updates are being hijacked and i suggest you download the Mozilla Firefox as a back up for surfing... Good luck, Sea Breeze
Hey Spyblaster is free and good for you computer!
Posted on Feb 02, 2009
ASUS Eee PC 4G PC Notebook screen blank... even press F8 to boot safe mode it freeze...
You operating system is corrupted and need to reinstall the operating system. If want to reinstall windows xp. here is the link how to install windows xp http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean
Dec 26, 2010 | Computers & Internet
Continuously rooboot itself?
Hi.
When the laptop keeps rebooting shortly after Windows starts loading the reason is usually because the system files loaded by Windows at startup are corrupted.
Windows cannot complete booting and keeps restarting.
The fastest way to Fix the problem is by reinstalling Windows.
If Windows is installed on the same directory of the existing system performing an upgrade installation, the setup process will preserve all personal files, most installed software and settings.
Before reinstalling Windows you can try starting in safe mode (eg. on XP pressing f8 on startup). If the computer starts in safe mode, go to system restore and perform a restore to a date before the problem occurred. Unfortunately when the computer keeps re-booting ut will hardly start in safe mode. Often reinstalling Windows is the only option available.
Aug 02, 2010 | Acer Computers & Internet
I HAVE IBM 8305-49U. ALL OF A SUDDEN IT STOPPED BOOTING OPERATING SYSTEM win xp PRO. iT REPEATS THE PROCESS OF START WINDOWS NORMALLY. EVEN IT DOES NOT BOOT FROM SAFE MODE.
Hi
Unfortuantley if you cannot get into safe mode, then windows is stuck ina loop, the easiest thing would be to reformat the machine and reinstall windows
Please leave feedback/vote if my answer was helpful
Feb 10, 2010 | IBM NetVista 8305 PC Desktop
Samsung r40 not loading xp
If the computer boots in to safe mode fine, you more than likely have a virus or spyware interfering with the boot process.
Windows also could have corruption on it.
Insert your windows XP CD and boot the computer, you may need to set your boot order in BIOS so tht CD is first.
Once the CD loads Run the recovery console Select 1 for the C: drive if it asks for a password this is generally blank or will be the password on the "Administrator" account you see when you boot to windows in safemode
Once in the recovery console do a chkdsk /f command
This is will check for errors on the disk and can fix a lot of boot issues
I would also suggest typing the command mbrfix to replace the master boot record.
If it still will not boot you may need to reinstall windows xp
Nov 02, 2009 | Computers & Internet
XP won't boot up.screen shows safe mode
The operating system files got corrupted.You can try repair the windows using operating system cd.
Siju
Oct 26, 2009 | IBM ThinkPad T60 Notebook
Won't boot past Windows XP main screen. Windows XP may have a corrupt file. How do I correct without full recovery?
Try starting in Safe Mode and check if you can start it? In case it starts in Safe Mode, you may do the system restore to the date it was working fine.
Aug 11, 2009 | Acer Aspire 3000 Notebook
Cannot reboot xp operating system due to power cut...
well ur window has been corrupted due to power failure.try to repair it or install it again.
Jun 26, 2009 | E-Machines (T2958) PC Desktop
Won't boot - brief blue screen
Press F8 while booting but before it goes into SAFE mode select "Temporarily disable restart." Now you should be able to read the Blue Screen. If this doesn't work it's likely you have the GenericFX virus and you'll need to repair the operating system.
May 30, 2009 | Computers & Internet
Windows xp will not install when booted
You have to reinstall windows insert you windows xp CD boot form it and wait untill it prompts you to repaire but only after you have press F8 you will find that repaire option because somehow your windows files are corrupt
May 08, 2009 | Intel Desktop Board D845GERG2 Motherboard
Boot up does not complete all the way
Can run BartPE that allows you to boot into XP on CD and fix the problem or replace missing files. This process does not always work right. The best bet is to get another HDD (hard drive) connect it where the original one was. Then install a fresh copy of XP on it. Then migrate the data you want off the older HDD. But making it a slave. The orginal one is called Master but there is also CS cable select more of automatic process.
If you don't want to replace the HDD you can still run the BartPE but the system you have there is unstable as you can't even get into the Safe Mode. If you could get into the safe mode I can tell you all you had to do is backup favorites, desktop, history, cookies and web links, then delete the profile or user name. That would create a new profile for that user under XP.
Jul 30, 2008 | Microsoft Windows XP Professional With...
HP PSC 1610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
