Question about Home
Clothes don't dry
We have an older model Whirlpool gas dryer model # GGQ88584Q0. When we put the clothes in and start the dryer, the dryer runs multiple times without drying the clothes. I thought it might be the thermocouple, but could find no way to access the heating element. The dryer was given to us by some friends about five years ago, the previous owners only had it for eight months and did not supply us with the owners manual. It looks like the front of the machine might come off, but again I could find no way to remove it. Any help in this situation or an instruction manual would be a great help. Thanks in advance.
    Problem Solver:
  • 19 Answers
Did you check the lint filter ?This is usually a common problem.Make sure it (lint filter ) is clean.
Posted on Feb 03, 2009
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
Jul 27, 2014 | Whirlpool Washing Machines
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
After setting dryer to the drying time and when you put the clothes in the dryer and shut the door the dryer starts without pushing the start button.
you will need to chnge the door switch. that part is bad causing the unit to run without touching the start button.
Oct 10, 2009 | Whirlpool Dryers
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
Moisture in dryer
is it cold outside clean your vent run dryer with out vent on gas dryer?
Feb 24, 2009 | Maytag LSE7806A Top Load Stacked...
My whirlpool clothes dryer will not start.
Hello Rick,
Use this link to get information for your dryer.. it should provide you with everything you need. Get back to me if you are still having problems..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Nov 28, 2008 | Whirlpool Dryers
Whirlpool Model LG5801XK Gas clothes dryer
first ck gas to unit, next is ck the coils on the burner valve right, there(i just looked up and this is an older unit) set of coils is about $85, the entire burner valve including coils and new ignitor is about $135.that would be my bet the whole thing but is it worth it putting 135 into the dryer
Feb 26, 2008 | Dryers
Home Logo
69 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
