Question about AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381
Compressor bad I have a 51/2 year old frigidaire refrigerator that the compressor has gone bad in. One month ago replaced relay overload start capacitor (3 in 1) when it stopped cooling. Now the compressor has grounded out.(checked with ohm meter) Any advice if I should replace compressor or buy new refrigerator. Will putting the 3in1 on the unit for this past month mess up anything else in the refrigerator? Thank you for any advice, I am very upset and confused on what to do.
    Problem Solver:
  • 19 Answers
I would think that compressor would cost a lot of money.So if I were you I would buy a new refrigerator .
Posted on Feb 12, 2009
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator not cooling all we hear is a clicking noise the compressor won't come on
Replace the start relay on the compressor. It has gone bad and causing the clicking sound.
Nov 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have an Amana SxS (model DRS2663B) that is about 8 years old. About a week ago, it started making a sound - kind of a buzz coming from the compressor area (or the little box I identified as a...
You may have a bad relay/overload part number 12555902 runs about $15 but if the compressor is going bad it may not work.If you take the relay/overload off  turn it into your hand and shake it if you it sprinkles out like a pepper shaker go with the OEM part afore mentioned,but if it sounds solid and nothing comes out go with a hard start(SUPCO RC0410 also about $15) it will buy you at least another couple years in which to shop around for a replacement or save the money for a new compressor.You can call Amana to check on the warranty but most only had five years on sealed system.
Sep 27, 2009 | Amana DRS2663B Side by Side Refrigerator
Compressor bad
its not DIY stuff to replace compressor. here is my video how i do it. replacing little compressor. pretty similar to any residential refrigerators.
Feb 02, 2009 | Frigidaire FRS26R4A Side by Side...
Whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Jan 16, 2009 | Whirlpool GS6NBEXR Side by Side...
Buzzing compressor
heres a part number for the overload relay assy 5304468029.. its mounted on the side of compressor. its a tricky one, usually my experience has been the noise comes from a bad compressor( which you should have 5 year full warr from manufacture). sometimes the overload relay does go bad preventing compressor from starting,the n ew compressor will come with a new overload relay
Nov 19, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire refrigerator
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Apr 27, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire gallery frigde is not cooling
If you never hear fan running in freezer, this could be the case. How old is this unit? Newer ones have a electronic defrost board. Older ones have a mechanical defrost timer.
If the fan in the freezer is on, and not getting cold...could be a compressor, or the relay/overload on the compressor. You'll need to check for voltage at the 2 wires at compressor. Should have about 110 volts when the freezer fan is on. If you have 110, Unplug unit and remove relay/ overload from compressor and shake it. If it rattles, you probably need the relay/overload. If this unit is only a few years old, it may be a compressor. We see these fail on these. Does it make a load hum for less than a minute followed by a click. And then after a bit, does it again. This is usually a bad compressor.
Nov 14, 2007 | Frigidaire FRS266ZDSB Side by Side...
AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381 Logo
102 people viewed this question
Top AO Smith Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an AO Smith Air Tool and Compressor Expert? Answer questions, earn points and help others
