JVC L-E5 Turntable arm will not move to the record.
Can you help me with this problem?
  • 104 Answers
This turntable is linear tracking, meaning that the tonearm slides from side to side. Inside there is a belt coming off a motor and over to a pulley that will move the tonearm from left to right n right to left. If you feel qualified it can be replaced with moderate from the bottom after removing the bottom cover with the power OFF. the belt can be found here.
http://www.turntableneedles.com/46-Inch-Square-Belt-Small_p_352.html
Posted on Feb 11, 2009
  • 1 more comment
  • bungitminor Jul 14, 2011
    I have exactly the same problem with my JVC L-E5. I am glad to hear that it can be sorted, so will summon my hi fi expert rather than trying to buy another turntable! Many thanks.
    Jenny
  • J Mark Cobb
    J Mark Cobb May 17, 2017
    I have exactly the same problem with mine, even after replacing the belt. Will look inside again.
  • J Mark Cobb
    J Mark Cobb May 18, 2017
    Determined that when I reinstalled the bottom cover after changing the belt, I had inadvertently put a screw into one of the four holes for shipping. When I removed it the unit worked like new.
Turntable arm not moving across record?
Try, without any record on the table, if you can move the are, to the centre of the table. If you feel anything that is holding the arm, try to find out what it could be. Never use force. Also look inside if you can't find a clear obstruction on the top of the table. If you should find anything, don't bent, or don't break anything. Let a technical skilled person look why the obstruction is there and where the "thing" should be so the aren can move free. Perhaps you ned the obstruction for something only a few centimetres to the left or the right.
Jun 26, 2014 | JVC Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Arm doesn't appear to make contact with record
arm lift mechanism not dropping full extent
Apr 11, 2009 | Audio Players & Recorders
JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Apr 07, 2009 | JVC AL A158BK Turntable
Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Aug 24, 2008 | Audio Players & Recorders
Table turns only once in a while.
The problem is probably the belt. When a belt gets old it tends to stretch and/or get stiff. Listen to see if you hear the motor turning. If it comes on when you lift the arm, it is not the switch.
Jan 27, 2008 | JVC AL A158BK Turntable
874 people viewed this question
 Grubhead
Grubhead
