Question about Canon SmartBase MP730 All-In-One InkJet Printer
Canon mp730 cartridge jam how to fix it? ink cartridges doesn't come out in the middle. thx in advance
  • 4,041 Answers
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 26, 2010
Canon 1p2770 ciss ink cartridge is not recognized
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Oct 27, 2017 | Canon PIXMA Office Equipment & Supplies
Lexmark 2400 series: the ink cartridge doesnot move across. The power light blinks. computer says there is a paper jam but there is not paper jam.
Hi
Open the back and front door and see the properly a small piece of paper make a error of paper jam, after that move your cartridge panel by hand, and check the cartridge fix properly, if cartridge not fix properly fix the cartridge and try again to print.
Thanks
Sep 02, 2011 | Lexmark Office Equipment & Supplies
I have a canon mp730 and since I have replaced my ink cartriges I keep geting a wrong cartridge message. I have checked and rechecked installation and re booted several times to no avail. I have checked...
Many times , if we use refilled ink cartridge , then also we might get such error messages on the printer display .
Ensure that you are using genuine Canon ink cartridges.. but if the error is after changing to a new set of genuine ink cartridges..
try by cleaning the electrical contacts of both ink cartridge and the printer.. and also do a semi full reset..
Aug 12, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Instructions on how to refill the the ink cartridge for a Canon mp730 .
You can easily to refill it only one time.If itself open cartridge and hole top of the cartridge push refill ink and close tide and tide.First time clean cartridge OEM software by printer default.
May 15, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I have a Canon MulitPass MP730. Wrong Cartridge message.
It's worth repairing, That error on a Canon is saying that the printhead is bad, not your cartridges. The part number for your printhead is stamped on the side of the printhead could be QY6-0049-000 but I'm not sure.
Jan 10, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Jammed cartridge error froCanon MultiPASS MP730 All-In-One InkJet
You can open up the device and look inside. You'll prob ably find a jammed peice of paper or a paper clip or some obstacle inside jamming either the rollers or the track for the print head, or both.
Nov 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Jammed Cartridge
You need to clean the encoder strip, the clear strip behind the carriage. You can wipe it carefully with a damp Qtip because with too much ink on it the carriage thinks it's not moving.
Oct 29, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
1200 error
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
YAY problem fixed.
Hope this might helpful to you.
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Lexmark X4270 All-In-One InkJet Printer
Canon SmartBase MP730 All-In-One InkJet Printer Logo
139 people viewed this question
old marine
old marine
