Question about HP Computers & Internet
HP Pavilion 250 watt PSU that includes a Nvidia GeForce 9300
I just don't see how this is possible... either this PSU is way to small or this video card is a cheap low grade piece that I just spent way to much money on. I also here that if you replace your PSU with a larger one you can fry your motherboard in these PC's.
I have upgraded an eMachines PSU to a 400 watter with no problem
when I replace it's vid card with a ATI HD2400.
How can this PSU be big enough? and can I upgrade it if I wish to without frying my motherboard?
  • Sonny
    Sonny Feb 02, 2009
    Thank you Machi, But would it normally take a much larger PSU than 250 watts to run a PC and a decent video card... like anything other than this GeForce 9300?
    Scholar:
  • 71 Answers
The maximum output of a PSU simply means it is able to supply a certain amount of power. It can also deliver anything under the wattage. Where you fry things is where the connectors are wrong. HP, COmpaq, Dell, IBM have all, at times, used nonstandard connectors in their PCs. If you take something with a standard connector, and use it in a machine where that connector needs to nonstandard, you can fry stuff.
Posted on Feb 02, 2009
Would Including additional hdds overwhelm the psu?
That depends on your PSU. What kind is it, how much wattage does it output, does it have enough cables to support that many devices, etc.
If it has enough cables to attach all of the hardware you have with no splitters than you are most likely ok. If you are not sure, a standard HDD uses anywhere from 0.5 watts to 12 watts of power depending on brand, make, model, and power saving features.
Aug 25, 2014 | HP Compaq Presario SR5050NX PC Desktop
HP pavilion a6567c pc won't come on
Open the case. undo all the cables from the PSU to the other bits inside. Then remove the 4 bolts on the PSU. Remove it. Then do the reverse. Make sure the power is off and disconnected before you start.
Apr 18, 2013 | HP Pavilion A6567C Core 2 Quad Q6600 4GB...
No picture with GeForce 210 graphics card
Picture? Are you saying it does not work? Is this a new install? Is it setup/installed correctly? Have you installed the software? Drivers? Need more info.
Mar 20, 2013 | HP Pavilion a1423w PC Desktop
Hp quad gets froze up while trying to delete or move files
Do your deletions and moving files on Safe Mode, it's faster.
Apr 27, 2012 | HP Pavilion A6567C Core 2 Quad Q6600 4GB...
FOXCONN MOTHERBOARD UYD761904374 PC661M04 MX 6L Will NVIDIA GeForce 9300 GE graphic card work with Foxconn motherboard UYD761904374 PC661M04 MX 6L. Please help me. I want to install windows 7 and use...
System Ram doesn't count for Gpu ram so 2 gig Ram and 2 gig Gpu will be fine .. check also Psu some Gpu are hungry for power Mine is Gtx770 8 pin + 8pin at 240watts.. hence 750 watt Flower power Psu...
Jul 01, 2017 | ASUS Computers & Internet
Does This Graphics Card Work With My Dell Inspiron 530s Even Though My Power Supply Is Only 250 Watts? Will my computer work with this card even though the PSU is only 250 watts?...
I think you're asking for trouble. The specs at the link you gave recommend at least a 300-watt supply. By the time you figure in the normal load of everything else in the system, there probably won't be enough power from the 250-watt supply to let the card work reliably, and may affect overall system operation. One of the problems with small form-factor computers is that they often use a proprietary power supply to fit the case, and you can't replace it with anything larger. This limits expansion capability. I'd suggest saving your money.
Aug 15, 2011 | Dell Inspiron 530s Desktop Computer
My geforce 8200 can not play fifa 11
Your graphics card is below the game minimum requirements (see link below) I would guess that this was a Dell, HP or other, and yours is basically a stripped down card with missing features, less memory etc. (which is why FIFA doesn't work) Your game also requires shader model 3.0, which will be present in all retail video cards on the list below.
From my information source site:
" Please note that NVIDIA GeForce 7300,8100,8200,8300 and 9300, ATI Radeon HD3200, HD4350, and Intel / S3 integrated chipsets are below minimum system requirement ."
http://gamesystemrequirements.com/games.php?id=956
If this is a desktop system, you can upgrade your video card to one of the following chipsets (video card series)
"Recommended Chipsets: NVIDIA GeForce® 6xxx series (6800 or greater) NVIDIA GeForce® 7xxx series NVIDIA GeForce® 8xxx series NVIDIA GeForce® 9xxx series NVIDIA GeForce® GTX 2xx series ATI Radeon X1600 (X1600 or greater) ATI Radeon X1800 ATI Radeon X1900 ATI Radeon X1950 ATI Radeon HD 2xxx series ATI Radeon HD 3xxx series ATI Radeon HD 4xxx series.
If you need help choosing a new video card, please repost your question and include the make (Dell, HP, etc. or white box) and model #. If this is a DIY project then please include as much information as possible about the mainboard, what version of windows, power supply, etc..
Once you know what you need I would check out newegg.com for video cards. They will have what you need at the best prices...
Feel free to contact me directly if you would like continued help with this.
Aug 02, 2011 | Computers & Internet
I have dell gx 260 with 2.4 ghz nd 1gb ddr ram with nvidia geforce fx 5200 can u name any graphics card which will be gud enough than geforce 5200...nd agp plz..
You need an AGP 8X graphics card for one.
AMD ATI Radeon series:
1) Better: XFX Radeon HD4650
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4914257&CatId=2234
A) 1GB (OR 1024MB) of DDR2 graphics ram memory
B) 128-bit bandwidth memory interface
C) 320 Stream Processors
D) 600MHz Core Clock
E) 800MHz Memory Clock
F) 55nm process technology
3) Best: HIS HD4670
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076197&CatId=2234
A) 1GB (Or 1024MB) of DDR3 graphics ram memory
D) 750MHz Core Clock
E) 1600MHz Memory Clock
Likes POWER! Better install a 500 Watt power supply, to keep up with the power needed for this baby!
The GX260 supposedly has a 250 Watt PSU. (Power Supply Unit)
Back in the day this PSU was made, the PSU manufacturer 'fudged' the maximum rated wattage.
Actual is more like 60 percent of what is stated.
175 watts!
The above is just IMHO about graphics card choice.
(I have motherboard's with a PCI Express x16 slot, using the PCI-E 2.0 technology.
I use Nvidia graphics cards)
Oct 16, 2010 | Nvidia G-Force FX5200 256M DDR 8X AGP...
NVidia GeForce 9300 265MB with a 250 watt PSU
GeForce 9300GE is the video card
GeForce 9300 is the motherboard
Also 250 Watt would not be sufficient for most new video cards. Most need a 450+ for requirements.
Giga Ethernet is short for Gigabyte Ethernet which allows for more speed if you have a higher speed internet service
Feb 02, 2009 | Computers & Internet
Computer freezes after about 10 mins !
It is possible the power supply is now too small for the number of loads you now have.Not sure what your CPU is ,but I bet it is 80 watts just by itself. The minimum wattage requirement or the video card by itself is 300 watts.Add the drives,ram,fans and mobo and you way underpowered.
Nov 25, 2008 | Compaq Deskpro 2000 PC Desktop
Computers & Internet Logo
172 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
