Question about Philips Magnavox MWR10D6 DVD Recorder
How do I hook up the mwr10d6 and set up to record from cable dvr or vcr? I play dvds ok when i try to record it was all scrambled like i might have hooked it up wrong somehow. Do not have instruction manual and cant' seem to find one online. Help
  • 8,596 Answers
Here is a link to the manual, but it is a little dense:
http://www.funai-corp.com/6pdf/om/MWR10D6.pdf
Now that the digital conversion is imminent, nothing will ever be simple again.
This is not the ONLY way to record with this machine, but here is one way: (I'm also assuming that you have a cable or satellite BOX - if you don't, let me know):
1. Connect a red, white, and yellow cable from a red/white/yellow OUT of your cable or satellite box to the Video IN and Audio IN of the Magnavox.
2. Connect a second red, white, and yellow cable from the Video and Audio OUT of the Magnavox to a red/white/yellow IN of your TV (most TV's only have INs and not OUTs, hence they may be unmarked either way - but this situation is rapidly changing).
3. Change your TV to the channel that corresponds to the red/white/yellow port - some TV's label it "AV1," "AV2" etc. - others label it "Video1", "Aux 1" etc. - I would have to know the exact model # of your TV to be sure.
4. As long as you can see the channel that you are trying to record on the TV screen, you can just press REC on the Magnavox with a blank DVD inserted.
Like I said, this is not the ONLY way, but it is probably the simplest.
-Tha Mp3 Doctor
Posted on Feb 15, 2009
How do i hook-up my vcr to my cable dvr to record saved shows
In order to record from VCR to DVR You need to connect "VCR audio/video output RCA jacks " to" DVR 's Audio / Video Input RCA jacks.. ..
use either "RCA analog (red/white+ yellow ) " or "optic " cable.(any standard optical cable )..if exist .optic is the best way to connect it..Remember your VCR 's "OUT" goes into" IN "of DVR ..
pls also remember,wherever you connect your VCR on your DVR ,you should switch the source selector accordingly to correspond to the connection on the back...
Now you can record anything on DVR which played in VCR ..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Motorola Televison & Video
I have a Toshiba D-VR16. How do I copy a VHS video onto a CD?
Just put the tape and a blank cd in and just press the Copy from the case.
Aug 10, 2010 | Toshiba Televison & Video
I need to know how to hook up my vcr to my dvr to record something off of it onto a vhs tape. directv said i need to contact the maker of the vcr & guess what RCA doesn't help with that. but i...
Ok. You connect the vcr to the televison first. Take an rca cable and connect it to the video out of the vcr then connect the other end to the av input on your television. Then take another set of RCA cables and connect them to the RCA av input on your vcr and connect the other end to the output on your dvr.
Now hopefully your tv has another RCA input you can hook directly to the dvr with another set of RCA cables to another one of the dvrs outputs. If not then don't worry about that.
Now make sure the tv is switched over to the av video RCA input the vcr is connected to and turn the vcr on. The vcr should be in input and when it is you will see the picture from your dvr and you will change channels with your dvr remote. You can now record using the vcr remote.
Jun 14, 2010 | RCA VR546 S-VHS VCR
I am trying to record from my dvr to my magnavox 10d6 recorder
Connect the yellow/red/white out from the VCR to the same inputs on the 2160. Press setup. select general. select video select video input. select L1 or L2. press ok. select video or s-video.
press setup to exit.
select HDD or DVD (whichever you want to record to)
use source or channel to select L1 or L2
press rec mode to select sp/lp/ep/etc
press record to start recording
start playback on the input device
press stop to stop recording.
The manual is available as a PDF file on the web. It would save a lot of typing...
tom
Jan 20, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
I HAVE A MAGNAVOX DVD RECORDER MWR10D6 AND I AM TRYING TO RECORD VHS TAPE FROM A VCR TO THE DVD RECORDER. CAN YOU HELP ME WITH THE CORRECT CORRECTIONS; NOTHING IS RECORDING
Play the video on your through your recorder if possible, then record it that way. It works for me. Just go to your watch tv setting and record it off channel three while the vcr plays the video.
Jan 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Pioneer dvr 225 recorder
the dvd recorder has to be set to monitor the program your watching! you can not copy vhs tapes to dvd this way because the tapes that are prerecorded have a copy protect feature and will nut copy right!
Dec 15, 2007 | Pioneer DVR-225 DVD Recorder
PioneerDVR-225 recorder
A lot of the functionality you are wanting is tied to the remote that you have misplaced. You can go to the Pioneer support site and order a new remote, though it is like $30.
As for wiring options to record, it depends on the inputs and outputs that are available on your television.
- Ideally, connect VCR to TV input "1", connect DVR output to TV input "2", and conect TV output to DVR. This will help you avoid any copy protection issues you run into, but not all TV sets have both audio and video output.
- If you don't have TV outputs, connect VCR out to DVR in, and then DVR out to TV in. This will definitely work, but you will have to have the DVR turned on to watch a VCR tape.
Nov 24, 2007 | Pioneer DVR-225 DVD Recorder
Recording from vcr
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Sep 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
232 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
