Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water keeps dripping from water dispenser in my kenmore coldspot
I have a Kenmore Coldspot 106 59567990. It is a side-by-side with ice and water dispensers in the door. I have had to turn the water off at the back of the refrigerator because otherwise water just drips out of the water dispenser. I have purchased part #4388152 which is a water-fitting assembly with tubing. Before I go to the trouble of taking off the freezer door and taking it apart to replace this, can you tell me if this is likely the problem?
  • Anonymous Feb 03, 2009
    1. The water dispenser keeps on driping after use. I had a repair man out, but it didn't solve the probelm. He put in a new tube with a circle type thing tha was supposed to stop it. I'll have to call again.
  • alcody25 Feb 21, 2009
    I have a Kenmore Coldspot too, with the same problem. For a couple months it would drip a little water periodically (8oz over the course of a couple days and then would stop for a few weeks). Now, it's dripping constantly at a rate of 8oz every 2 hours.... We're turning off the water but would love to know what the heck is causing the dripping and how to fix it.
    Thanks in advance for any help you can provide!
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
  • 1214 Answers
SOURCE: water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Posted on Jan 20, 2009
  • 163 Answers
SOURCE: GE TPX24 BRBJ side-by-side drips water from door dispenser
water valve is behind ref.on either the right side or left but you will see your water line going to ref.water valve.Most likely replace.
Posted on Mar 06, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
  • 93 Answers
SOURCE: We have a Kenmore Coldspot
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Posted on Sep 12, 2009
Ice dispenser not dropping ice using dispenser knob
If you can hear the auger motor turn, you may have a large chunk of ice in the hopper.
Jul 25, 2014 | Kenmore Refrigerators
I need the housing for my ice/water dispenser Kenmore Coldspot 106.56926600
Part Number: 8201756
http://www.applianceblog.com/mainforums/sears-kenmore/16912-kenmore-dispenser-housing-broken.html
Jun 11, 2012 | Kenmore Refrigerators
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
393 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
