Question about DeLonghi EC155 Espresso Machine
Delonghi EC 155 general help
Hi
I am complete newbie to coffee brewing and just got the Delonghi EC 155
I read through the instructions which talks about pre-heating the unit for 15 mins
After pre-heating, should I just run hot water through and the fill the filter?
It takes atleast 5 -6 mins to get some decent espresso . Some times, steam starts coming out the unit.
What am I doing wrong here?
  • HP12 Sep 18, 2009
    I have the same problem too and looks like my brew pressure is
    considerably low compared to when I got the machine a couple of months
    back, BTW, I cleaned the machine as per the instructions i.e. using the
    both the commercial and the citric acid method but there is no
    improvement. Hope somebody can help us.
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Posted on Feb 06, 2009
Unable to remove infuser, no warning light, reset multiple times, brews coffee fine
You should go to test mode and try moving infuser up and down to position when you can take it out it needs some skill of timing. After that you need to disassemble infuser completely clean it up and lube with special food grade lube. Also there could be a problem with transmission kit that cause this problem.
Mar 22, 2014 | DeLonghi ESAM3300 Magnifica...
Need to download the DeLonghi ec-155 user manual
Hi.
Please click on the link below to download the manual in PDF format:
Delonghi Manual EC-155
Regards.
Ginko
Oct 24, 2011 | Coffee Makers & Espresso Machines
How do I program my DeLonghi DCM 485?
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | DeLonghi DCM485 Coffee Maker
Suddenly stopped working.
If you are talking that the while unit failed or just the coffee? If the light comes on and the coffee is not brewing than it is the heat plate fuse. You need tamper torx bits to open the unit and replace the fuse, radio shack sells them.
Mar 12, 2011 | DeLonghi ® Combi CoffeeEspresso Maker
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
My DeLonghi DCM485 coffee maker will not brew coffee. Cannot find any troubleshooting to solve it. Help
The same thing happened to me....At least you got three years out of yours, I got three months.
Aug 09, 2008 | DeLonghi DCM485 Coffee Maker
DeLonghi EC155 Espresso Machine Logo
1,408 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
