Batteries for innovage 12 digit calculator
I've been given a 12 digit Innovage electronic calculator but no battery was included. Which battery is required? The only details on the calculator are as follows: DC:AG10 (1.5V)
  • 7993 Answers
SOURCE: TI 86
If batteries are inserted correctly you can adjust the contrast
Press [2nd] key and release it
Press and hold [UPArrow] key to darken till contrast is dark enough.
To enlighten screen, do as above but use the [DownArrow] key.
Hope it helps.
Posted on Sep 23, 2009
  • 7993 Answers
SOURCE: My kid's calculator is not working; replaced new
After a battery replacement the screen contrast may become too dark or too light. I suspect that in your case the screen is too light. To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] until screen darkens enough.
Posted on Jan 30, 2010
prajs
  • 126 Answers
SOURCE: dear sir, about casio scientific calculator
u have to check the the correct polarity of the cell and the calci.... put the cell in all combination and press ON key.... if still u have problem ur calci might have some internal problem that u can't solve.......
for more contact prajwal_yes@yahoo.com
Posted on Feb 25, 2010
  • 102366 Answers
SOURCE: TI-83 Plus calculator won't turn on. Replaced all
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't do it, append a comment here and we'll go on to the next step.
Posted on May 21, 2010
  • 102366 Answers
SOURCE: TI 83 plus calculator has dim screen.
TI calculators have an annoying habit of dimming the screen when the batteries are changed. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Posted on Jul 19, 2010
Instruction manual for speaker phone generation gm-7826
http://www.scribd.com/doc/6658509/INNOVAGE-Panel-Caller-ID-Speaker-Phone-Manual
Jan 19, 2014 | Innovage Speaker/Caller ID* LCD Touch...
I have a Shift 3 lcd touch panel phone with 12 digit calculator.I cannot find the manual for this phone.I can receive calls but cannot call out.A manual would be helpful Thanks
  • Check your phone to make sure it is set up properly. Open the back of the phone by pressing your fingertip on the small lever that opens the battery area. The battery cover will come off in your hand. Insert three "AAA" batteries into the back of the phone so you can use the night light feature. Replace the battery cover by sliding it into the battery area and clicking it into place with your fingers. Connect the phone to the telephone phone jack by connecting one end of the wire to the phone and another end to the wall jack. Connect the handset to the phone by inserting the end of one end of the curly phone wire to the handset and the other end into the side of the phone. Listen to the dial tone by pressing the speakerphone or picking up the handset to make sure your Innovage LCD touch panel phone is connected.
  • 2
    Review calls you missed. Use the up and down arrows on the Innovage LCD touch panel phone to view the caller ID phone numbers.
  • 3
    Use the night light to view the Innovage LCD touch panel in the dark. Slide the switch on the front of the panel to turn the night light function on. Slide the switch to the off position to turn the night life off.
  • 4
    Adjust the volume on your speaker by selecting the speaker loudness that you want. Press the hands free button once and press the "Delete" button. Choose a loudness from one to four.
  • 5
    Press the hold button on the front of your Innovage LCD touch panel phone. This will activate the hold function when you are on a call and it will allow music to play while someone is on hold. The hold music is built in to the phone and will automatically play when you press hold.
  • 6
    Save a phone number as a VIP number on your Innovage LCD touch panel phone. Press set and save when an important number comes onto your caller identification. This makes it harder to delete the phone number by accident.
  • Read more: Innovage LCD Touch Panel Phone Instructions ' eHow.com http://www.ehow.com/how_7256783_innovage-touch-panel-phone-instructions.html#ixzz1eMIaaXLV
    Sep 23, 2011 | Innovage Speaker/Caller ID* LCD Touch...
    I NEED INFO TO PROGRAM PRODUCT
    I USED THE SEARCH ENGINE BING, TYPING IN THE INNOVAGE PHONE AND THE PAGE THAT CAME UP HAD A REFERENCE TO A MANUAL. IT WAS ACTUALLY FROM SUPPORT FROM FIX YA. THANKS FOR YOUR CONCERN.
    Jan 05, 2010 | Innovage Speaker/Caller ID* LCD Touch...
    How do i turn the ringer off? Innovage LCD flat
    there is a tiny button at the base of the phone, just to the right of where the phone jack is plugged into the phone. Three settings - Hi, Lo and Off
    Oct 28, 2008 | Innovage Speaker/Caller ID* LCD Touch...
    Speaker volume
    hi fshmol, press the HANDS FREE button, press delete to select LOUNDNESS (1-4), then press HANDS FREE to confirm, then DELETE to exit to main view.
    tammy
    May 16, 2008 | Innovage Speaker/Caller ID* LCD Touch...
    No response on screen
    sent you an email of the manaul i have, hope it helps ya out.
    tammy
    Apr 17, 2008 | Innovage Speaker/Caller ID* LCD Touch...
    No Manual
    I wonder if my pamphlet would help? Its made by Takashi aka: Innovage and it's so identical in every way. I have the pamphlet but it's pretty vague. I could scan it and attach it here if it would help. Lorrie
    Feb 07, 2008 | Innovage Speaker/Caller ID* LCD Touch...
    159 people viewed this question
    jasbo
    jasbo
